-   -   P/S Or More HP? (https://www.racingjunk.com/forums/showthread.php?t=17301)
nascarlatemod06 05-17-2007 04:35 AM
P/S Or More HP?
My race car has no power steering... The Steering system is setup for power steering though... So I'm just assuming that whole P/S system was removed for the gain in HP... My question is: Is it really worth the gain in HP to remove the P/S system? Or should I add it back on?
billhendren 05-17-2007 04:53 AM
Power steering takes very little H.P. to operate,unless you are running a class that is extremely limited in H.P. I would go back to the power steering for the better handling and ability to use a faster ratio.Bill
alscoupe 05-18-2007 02:05 AM
I agree with Bill (and he would definitely know), however, be aware that as soon as I swapped my '69 stepside over to P/S, I can't keep my leadfoot wife out from behind the wheel! That reminds me, I need a new pair of 50's out back now too.
nascarlatemod06 05-18-2007 05:04 PM
Lol Alrighty than... P/S Pump is going back on! Thanks guys
edvancedengines 05-18-2007 06:15 PM
When I was racing with my BB Chevys and also driving those on the street. I never had to make the decision. My engine made that decision for me. I lost the power steering belt every pass until I just said forget it. I did have a clutch car though so that might make a difference.
Ed
lively 05-18-2007 09:12 PM
POWER STEERING IS JUST ONE MORE THING TO SCREW UP GOING 100 MILES AN HOUR THAT CAN GET YOU KILLED VERY FAST!!!!- :oops: -I WILL TAKE MANUAL STEERING ANY DAY FOR A CAR SCREAMING DOWN A DRAGSTRIP---BEEN THERE/ HAD BAD EXPERIENCES/ WON'T DUE IT AGAIN :? :?
cepx111 05-18-2007 10:14 PM
My old 73 nova had a power steering unit on it that was on the car when I got it with the holes plugged up on the gear box where the lines went, it was very hard to drive in the pits with that thing but I dealt with it cause like the others said its just something else to either get you killed on the big end our put you out of the race for a leak or something stupid like that.
I came across a manual box for my nova and I thought I had power steering it was so nice, not to mention it was considerabliy lighter than that p/s unit so I chunked it and never looked back.
billhendren 05-19-2007 10:13 AM
Going by the guys handle nascarlatemod06 I assumed it was a circle track car he was asking the question about.Bill
bjuice 05-19-2007 02:45 PM
i am with Livley...MANUAL STEER for me also..to easy to over steer a power steer drag car....if you cannot find a manual box ..you can plug (loop) the power steer and have it re-worked for a quicker ratio and a different pitmit arm that will suit the dragstrip...My wifes 69 camaro is a power steer i looped the lines and with her 3 inch rims and front runners..its not that bad for her even in the pits....now a street car with 8 inch front wheels can be a bitch with plugging a power steer as you probably know already..
brian
sp2816 05-19-2007 07:34 PM
Bill,
You are correct and he had some of the posts which are no more. He has recently picked up the car (a Buick Regal with 350 and manual 3-speed) and the previous owner had done a lot of option deletes .... sway bar link, front shock, oil dipstick, and the power steering pump.
nascarlatemod06
I don't see how you could have the "feel" of the car with a power steering box and no pump. So, I think that what small amount the ps pump would use that you could make it up in handling. But, I guess it would depend on the speeds, size of the tires, and the type of track. I don't have any experience on this, but just a thought.
Bill M
