-   -   Estimated E.T. (https://www.racingjunk.com/forums/showthread.php?t=17282)
bryanm 05-15-2007 03:05 PM
Estimated E.T.
Hey guys. I am almost ready to take out my car that I have been building for the last 3 years and wanted to gets some opinions on what it might run. The car is a 1991 Mustang that weighs approx. 3000lbs. The motor is a 408 CI windsor with 13:1 pistons a .672 .668 lift roller cam with .268 int and .272 duration. Edelbrock Victor Jr intake, 195 Ported canfield heads, 800 cfm Mighty demon carb, C6 trans with a 5000 stall converter and an 8.8 with 4.10 gears. I know I am lacking a litle in rear gear but the car was built for a lot more motor than what is in it now. Also I am from MT where we race around 6000 feet. I hope that the car will go high 6's in the 1/8. Let me know what you think.
slowman 05-15-2007 08:27 PM
bryanm, my fisrt engine in my mustang was about the same as yours. my car was 406 ported heads roller cam about the same spec's as yours but mine was a small block chevy. both cars are very close in weight ,gear etc. i ran 10.48 at about 1000ftelv. i have to think that yours should run 10.6-7s at 6000ft in the 1/4 mile or better. there is calculater to figure out the change from 1000-6000ft that would give you a better idea on how much i would of lost going to 6000ft. good luck, bring it out of the clouds at it should fly :D :D :D
cepx111 05-15-2007 11:18 PM
I beleive with that combo it should run in the high to mid 6's in the 1/8 mile easy if it hooks up, what tire you got on there?. may even run faster with more gear like a 456 or 488.
bryanm 05-16-2007 05:30 AM
I run 28-10.5's on it. Yeah I know it is lacking some gear but I planned to build a Yates headed 430 CI small block for it but didn't have the funds at the time. I will see how it works with the 4.10 and maybe put in some 4.88's and see how that works.
