-   -   welding flux or argon??? (https://www.racingjunk.com/forums/showthread.php?t=17274)
jaykz1000 05-14-2007 06:37 PM
which one u guys think is better ??? pros and cons on both?? and which is stronger
mcracecars 05-14-2007 11:49 PM
Since you said "flux" I would assume you are mig welding.
Flux core wire is ok, but you need to clean off the weld after. For gas use a co2/argon mix , it is 75/25 of each. Do not use strait argon with mig, and do not use the co2/argon mix with tig...
jaykz1000 05-15-2007 08:04 AM
yes mig welding some brackets on a chassis ..so u think flux wire will be ok i have read that it penetrates better but not as pretty... yes i clean it with a wire brush after every weld....seems like it hold really good just thought about switching over since i already got wire just need argon...
alscoupe 05-15-2007 10:49 PM
Yeah, pure argon is for TIG welding aluminums and stainless,or the exotics like chromemolly. Be CAREFULL! the way it works is by displacing oxygen. It can suffocate you quick in a confined area.
With an ER70 series solid wire on mild steel (1040's) CO2 is just fine and least expensive. 75/25 and TriMix generate more heat but don't figure in to the strength given the same penetration and bead profile. Largely dependent on deposited weld metal strenght (ER70=70,000psi tensile) and profile (width, height, depth....)
Several manufactures offer quality Flux-cored wires, in various diameters.
As with most welding proceedures, the final "strength" (quality) is proper proceedure by the operator (skill).
Proper equipment, materials, and application = success!
If you'd like, give me model machine, dia wire, mat'l thickness, etc. and I'd be glad to give you specific pointer's .
bryanm 05-16-2007 03:24 PM
I have found that using an argon mix makes for a better weld with less spatter but doesnt necessarily penetrate any better, but I would definatley use argon instead of using flux wire. Maybe I just never got the hang of it but the beads always seemed to be bigger and bulkier than with other wire.
