-   -   Carb suggestions!! (https://www.racingjunk.com/forums/showthread.php?t=1297464)
Devilman666 06-20-2022 02:07 PM
Carb suggestions!!
I hav a 468 bbc with a 1050 dominator on it. Was thinking to changing to efi. Holley sniper. Any thoughts on it u guys???
DeborahMorales 04-12-2026 10:02 AM
A 468 BBC with a 1050 Dominator is right in the sweet spot where a Holley Sniper can work, but you need realistic expectations. From what most builders report, the Sniper setup runs great for street use—better cold starts, altitude compensation, and smoother drivability—but it won’t really outperform a well-jetted Dominator at full throttle. It’s more about convenience than peak power. The main thing is making spinaud.bet sure your fuel system is solid (high pressure pump, proper return line) and your ignition is clean, otherwise the self-learning can struggle. A lot of guys running big blocks say it’s a “drive it everywhere” upgrade rather than a race upgrade.
