-   -   Small block Mopar thrust bearing problem (https://www.racingjunk.com/forums/showthread.php?t=1297372)
GSI_111415170813302723143 11-09-2021 12:47 AM
I haven’t ever seen this before, but the crank looks to be pushed forward from the torque converter and is wearing down the thrust bearing. This is a cast crank 340; there is about a 1/8 to 3/16 gap unbolted between flex plate and converter. Spins freely, and moves back and forth easily. The forged crank 340 has no problem with same Trans and converter. Any ideas?? Thanks
