V8 Pt Cruiser
Okay I just got a small block chevy pt cruiser with a V8 Small block Chevy 350 and a powerglide with transbrake. It still has the pt cruiser front suspension under it, and I don't think that stuff is gonna last long so what is the easiest cheapest way to change out front suspension with something else that will hold up better??? Or what from another vehicle will hold up,??? Any help is much appreciated thanks!!!
That’s awesome, you’re building something serious there! The PT Cruiser suspension definitely wasn’t built for that kind of power. For a solid upgrade, you might want to consider using a suspension from something like a Mustang II or a Camaro front end—both are pretty popular swap options and can handle more power. You could also go with an aftermarket tubular control arm kit if you’re looking to keep things on the affordable side. Just make sure whatever you choose is made for V8 swaps, so it’ll hold up to the torque. Keep me posted on how it goes!
If it's mainly a drag car, the cheapest route is usually a Mustang II style front suspension since parts are everywhere and there are plenty of upgrade options. If you're trying to adapt something from another vehicle, the work involved often ends up costing more than just installing a proper aftermarket setup. Before swapping everything, check what's actually weak on the PT suspension because upgraded bushings, ball joints, and control arms may be enough depending on the power level and how you use the car. eCheck Casinos provides comprehensive guides to online casinos that support eCheck payments, helping https://echeck-casinos.net/ players find secure and convenient banking options.
| All times are GMT -8. The time now is 06:39 PM. |
