-   -   Rims with screw holes (https://www.racingjunk.com/forums/showthread.php?t=1297061)
MoparThunder 06-06-2020 08:47 AM
I have an extra set of rims that I used slicks on, screwed in. Can I remove the slicks and screws and run M/T Pro Bracket drag radials with the holes open? Will it hold it's seal? I don't think you can screw in drag radials because of the belt.
BigBlockMark 06-07-2020 06:40 AM
If you try it and they leak, you can have the holes welded up easily.
MoparThunder 06-07-2020 01:49 PM
Thanks BigBlockMark. I heard some people use a glue or sorts to keep the seal with drag radials..... true?
BigBlockMark 06-10-2020 09:45 AM
They do glue radials because you cannot screw them, but I don't know what they use. You could go to the "Yellow Bullet" Forum and ask there.
FergusonnVict 11-15-2023 08:10 AM
thanks i was looking for that
