10.2 tall deck bbc rotating assembly?
What would be a good setup as a rotating assembly for a 4.280 bore 10.2 deck bbc? It will be set up with a 871 blower and it will be in a 3500lb 10.5 tire drag car. 4.25 crank? 4.385 crank? 4.25 crank with a 6.8 rod with 1.27 piston ? Whats your guys preference? What have you built and owned? What do you suggest?
| All times are GMT -8. The time now is 08:25 PM. |
