-   -   How much am I leaving on the table? (https://www.racingjunk.com/forums/showthread.php?t=1290119)
cbtlr 04-01-2017 08:36 PM
This is a sbc 350 with modified Edelbrock Performer heads.These heads will flow decent out of the box up to .575 lift.My current cam is the XE274 .490/.490 230/236 at 110 lsa.
Pump gas motor 3600 10 inch stall verter with 3.73 gears car weighs ruffly 3800 pounds.Best pass to date has been a 7.45 in the 8th mile on a 150 hit off the bottle.
I would like to revise the cam sense the heads will allow more lift/more volume.Motor runs very well I just dont want to screw up the combo or make changes such as new converter or change the rear gear ratio.
If this helps at 6000 rpms 8th mile its done on making any steam..
Swiley383 04-02-2017 09:36 AM
What compression? Sounds like it needs
More cam. It should run close to 7.45 on motor. What's the mph?
Swiley383 04-02-2017 09:37 AM
What's the motor only ET and mph?
cbtlr 04-02-2017 12:01 PM
Compression is unkown after heads were milled but I would suspect 10:1 or just a tad under.
Best I got it to run on the motor was a 8.21.
On the hose mphrs is at 90.01 in the 8th.
I dont have the times slips anylonger when I ran on the motor.But if memory serves me correctly on the motor I was in 78/80 mphr zone.
Thanks
cbtlr 04-02-2017 12:03 PM
Motor pass the car in question is the Impala.https://www.youtube.com/watch?v=vx0B0DlCC_4
cbtlr 04-02-2017 12:05 PM
Nitrous pass..https://www.youtube.com/watch?v=F5EEA2O9ZnE
cbtlr 04-12-2017 10:19 PM
This site had a lot more traffic years ago.I wont let the door hit me on the way out.
Thanks RJ had fun way back when..I'm out good luck to the rest of you racers...
Swiley383 04-13-2017 06:15 PM
Looks to definitely need more cam. What size carb and intake are you running
