-   -   richmond 3rd cluster gear 25-518 30 tooth count (https://www.racingjunk.com/forums/showthread.php?t=1290006)
mychevelle540 10-11-2016 08:39 AM
i have contracted a machine shop to reproduce the third cluster gear part number 25-518 30 tooth as motion gear bought Richmond and they are not going to make this gear any longer so if you need one see my add and get in touch thru the add i can get you back to banging the gears again these gears will be made out of 8640 steel and heat treated not a cheap deal but stronger than the o/e one which was made from a lesser strength material
