motor mounts
Need a little,
Bought a 1978 malibu this summer,bracket car.406 sbc,trans brake,Rec tube from firewall back, stock front frame.The question i have is,pulled motor to freshen up,noticed the engine is leaning back alot.maybe 10 deg.or better.Is there a max angle the motor should be set at?I need someone who can advise me what to do.Thanks alot. |
Is that with the trans attached and the crossmember in place? Is the trans and crossmember stock and what kind of trans mount does it have on the crossmember?
Oh and are your engine mounts solidor rubber? |
Thats with the engine and trans in car.Solid motor and fabed trans crossmember.Looks like stock trans mount.
| All times are GMT -8. The time now is 07:39 PM. |
