Originally Posted by mrmopar622
The dyno operator & I went over all the data and called over to a Ron's dealer and had him come over and look over the data with us.Everything is within specs.
Looking at the dyno sheet that Naylor had you post, my engine is way down on power from the beginning compared to that 1059 hp engine. |
There is no fuel pressure issue's,if they were we would have corrected them on the dyno!
A couple yrs ago i was helping a friend with a 512" Ford motor setup a 4.1 toilet bowl on his car. It kept laying down about 7,000 RPM's and would only run 5.80 in his 2400 lb T'bird. As i said earlier i donot use Ron's pumps. I sold my friend a DSR -1 pump and the car immediately went 5.62,5.64,and 5.65 before it broke the rearend housing in half, just saying. Also what size nozzles are you running :?: They should be .038's or .040's with that many inches. Either one or both of these issues could cause the motor to be down on power. Again that's why i run DSR or Enderle pumps i know exactly what the flow rate is and what the pressure is. JMO Zip. |
A fresh of eyes could actually help you Billy. If you have egt and/or o2 numbers for the entire pulls, we could put that issue to rest right quick. David is "the man" for running alcohol and Ron's stuff and will help you if you let him. I know you are certain that it's not a fuel system issue, but an opinion from someone who knows his stuff and doesn't have a dog in this fight might be a good idea......
Johnny |
Hi Zip,
We had a Ron's dealer who sells, installs & runs them on his own car come & look at the dyno results that showed the fuel pressure, EGT and CO2. They were all within specs, if there had been anything questionable on the fuel system we would have corrected it right then. The engine made the most power with #40 nozzles and #86 pill in the return line, timing at 32 degrees. This setup made the most power any leaner or richer resulted in a loss of hp. In other words, we fine tuned the fuel system & timing to get the most hp possible. |
Hi Zip,
We had a Ron's dealer who sells, installs & runs them on his own car come & look at the dyno results that showed the fuel pressure, EGT and CO2. They were all within specs, if there had been anything questionable on the fuel system we would have corrected it right then. The engine made the most power with #40 nozzles and #86 pill in the return line, timing at 32 degrees. This setup made the most power any leaner or richer resulted in a loss of hp. In other words, we fine tuned the fuel system & timing to get the most hp possible. Zip. |
Clearly ... I see you correct a lot on the dyno, anyone that pulled a big engine like that one time and seen it lay over at 6000 anything rpms wouldnt of pulled it twice without looking for that issue ... I can now see why no one would want to help you ... you side step questions .. give know it all answers ... clearly u got it all figured out :!: |
Clearly ... I see you correct a lot on the dyno, anyone that pulled a big engine like that one time and seen it lay over at 6000 anything rpms wouldnt of pulled it twice without looking for that issue ... I can now see why no one would want to help you ... you side step questions .. give know it all answers ... clearly u got it all figured out :!: I have answered your questions, not side stepping anything. I had one of the best dyno operators with the latest newest dyno that was also good and used to dynoing engines with Ron's terminators & flying toilets on alcohol. There is no fuel pressure problem whatsoever. However, if you are so sure there are fuel pressure problems - PUT YOUR MONEY WHERE YOUR MOUTH IS!! I will be happy to bring my engine and dyno sheets & put the engine on the dyno, if there is a fuel pressure problem that you can correct and pick the engine up 153 hp like it should be you win the money, if not, I win the money. |
Clearly ... I see you correct a lot on the dyno, anyone that pulled a big engine like that one time and seen it lay over at 6000 anything rpms wouldnt of pulled it twice without looking for that issue ... I can now see why no one would want to help you ... you side step questions .. give know it all answers ... clearly u got it all figured out :!: I have answered your questions, not side stepping anything. I had one of the best dyno operators with the latest newest dyno that was also good and used to dynoing engines with Ron's terminators & flying toilets on alcohol. There is no fuel pressure problem whatsoever. However, if you are so sure there are fuel pressure problems - PUT YOUR MONEY WHERE YOUR MOUTH IS!! I will be happy to bring my engine and dyno sheets & put the engine on the dyno, if there is a fuel pressure problem that you can correct and pick the engine up 153 hp like it should be you win the money, if not, I win the money. How much money you offering .. I get to bring it to a dyno of my choice to make it show 1100 ... easy to flip a dial and make a dyno show what you want, of course you have it in your head that every dyno in the country reads the exact same number and cant be changed ... I can now see why your getting zero help from Naylor ... you act like this to people who offer you advice or help ... your defensive .. and pretty much a prick about it, to anyone and everyone who has anything to say but your 100% right ... |
Hi Zip,
| All times are GMT -8. The time now is 08:28 PM. |
