TO ALL THE MORONS
CAMARO WAS DYNOED AT HORSEPOWER SOLUTIONS IN HAMPTON ...IT TURNED ON THE FIRST PULL 340 HP AT THE WHEELS, 2ND PULL WAS 368 HP AFTER A TIMING CHANGE AND ON THE THIRD AND FINAL PULL AFTER A CARB JET CHANGE IT TURNED 370 HP.... ON A 200 SHOT OF SPRAY THEY BELIEVE THE CAR WOULD BRING 525 HP MAYBE.....THESE GUYS THAT TUNED THIS CAR WERE TUNING CARS BEFORE NUMB NUTS EVEN DREAMED OF RIPPING PEOPLE OFF....WENT TO VIRGINIA MOTORSPORTS PARK TODAY HOPING TO SEE BILLY BAD ASS BUT NO LUCK...SO WE RAN THE CAR IT RAN A 11.98 @ 111 MPH....60 FOOT WAS 1.70....NOT THAT GREAT BUT FOR A 3500 LB CAR OH WELL.....HE GOT ME AND HE GOT THE BETTER OF THE DEAL....I AM OVER THE CHILDISH GAMES BUT IT IS FUNNY I HAVE OFFERED THE BATTERY BOX AND SHUT OFF SWITCH AND BOTTLE TO MR. LITTLE AND OF COURSE LIKE EVERYTHING ELSE HE HAS AN EXCUSE.....DONT BE SCARED ALL YOUR LIFE BRO....
Re: TO ALL THE MORONS
A 408 with the parts he listed should be able to make 500 hp in my humble opinion. |
Here is what he posted he said about the car.....
"here is a list of parts copied directly from here..... so what is not true about the camaro??????????????????? This is a Super Clean 1981 true z28! this was originally a 4speed car and all pedals are still in the car. car is a deep blue color with real recaro seats. 295/65/15 drag radial car (new!) 81 Z-28 drag \street rolling chassis 8.5" 10 bolt, Mark williams 35 spline spool and axle kit, 3.90 richmond gear set. Aluminum pre-load diff cover. Competition eng slapper bars. Rancho 8 way adjustable rear shocks. Comp eng 90\10 front. Del-a-lum bushings upper and lower control arms. Convo pro wheels. Recaro seats. 8 point roll bar. Rci belts. 4" glasstec cowl induction. Dual 1\2" fuel systems T-tops,Rust free, solid and clean new factory carpet new headliner ________________________________________ Here is a little info on the engine . I have all reciepts for the engine work including the build sheet from Randalls racing in Chester Va. 408 sbc eagle crank 6 inch eagle h beams kb 12.6 to 1 pistons Dart iron eagle platinum 230 cc heads bullet racing 645 645 solid roller 7/16 1.5 scorpian roller rockers Holley keith dorton intake AED Holley 750 ho modified carb csi electric waterpump double roller timing chain msd digital 6plus Mallory HEI Dist Howe radiator Trans and oil cooler 5500 nitrous converter Th400 Manual valve body Forward Pattern Line lock ************Most parts are brand new.... i have not run it at the track yet because I am still tuning the car. there is no reason this car wont go into the low to mid 10s on motor and pretty deep into the 9s on the gas once tuned .************ HMMMMMMMM!!!! |
"here is a list of parts copied directly from here..... so what is not true about the camaro??????????????????? This is a Super Clean 1981 true z28! this was originally a 4speed car and all pedals are still in the car. car is a deep blue color with real recaro seats. 295/65/15 drag radial car (new!) 81 Z-28 drag \street rolling chassis 8.5" 10 bolt, Mark williams 35 spline spool and axle kit, 3.90 richmond gear set. Aluminum pre-load diff cover. Competition eng slapper bars. Rancho 8 way adjustable rear shocks. Comp eng 90\10 front. Del-a-lum bushings upper and lower control arms. Convo pro wheels. Recaro seats. 8 point roll bar. Rci belts. 4" glasstec cowl induction. Dual 1\2" fuel systems T-tops,Rust free, solid and clean new factory carpet new headliner ________________________________________ Here is a little info on the engine . I have all reciepts for the engine work including the build sheet from Randalls racing in Chester Va. 408 sbc eagle crank 6 inch eagle h beams kb 12.6 to 1 pistons Dart iron eagle platinum 230 cc heads bullet racing 645 645 solid roller 7/16 1.5 scorpian roller rockers Holley keith dorton intake AED Holley 750 ho modified carb csi electric waterpump double roller timing chain msd digital 6plus Mallory HEI Dist Howe radiator Trans and oil cooler 5500 nitrous converter Th400 Manual valve body Forward Pattern Line lock ************Most parts are brand new.... i have not run it at the track yet because I am still tuning the car. there is no reason this car wont go into the low to mid 10s on motor and pretty deep into the 9s on the gas once tuned .************ HMMMMMMMM!!!! I think the part you are overlooking is the fact that He also told you HE HAD NEVER RAN THE CAR!! Now, unless you believed he had a crystal ball how could he possibly do anything but guess as to what ET it would run? If the parts list on the engine was accurate then he did nothing wrong in predicting the ET....he just was incorrect. I wouldn't have believed low 10's from that list of parts IN THAT HEAVY CAR, I would chalk it up to bench racing /guessing....that isn't a slam on him or the engine. He either exaggerated or guessed wrong but IF that list of parts is correct I don't see where you have any right to complain about the performance..it would be MUCH DIFFERENT if he had TOLD you that the car HAD ALREADY ran those numbers. JMO on things, but he said he told yoyu 500 hp or slightly more??? 500 HP won't even get a 3500lb car to go low tens.You would need over 600 |
All I see right now is buyer/trader remorse. But that is My Opinion
x2, I think tod sums it up well. :roll:
[/quote]
The cage actually looks a ton better than the one in the mustang. 11.99 thats funny....it had half the enging last year and went 1/2 a second faster at 118 mph..... the guy tuning it needs to have someone else tune it cause he doesnt know what he is doing.....[/quote] I'm sorry if you guys feel that I was wrong for posting anything on this forum, and you may think that there is not much of a dif. in a 302 and a 306 in the case of the mustang and there may not be, however I contacted Mr. Tony via e-mail asking him to correct his add on the mustang before I came here. It was more than just the size of the engine that was imbellished on in his add. He simply ignored me and told me to mind my own buisness along with several other choice words he had for me. I only wanted to make sure that the person that bought the mustang knew exactly what they were getting. I have stated several x's that it is a great car and worth every bit of his asking price. Just wanted him to be honest about the car... Thats all... As for the Camaro he stated several x's the car would run 10's or better. Ok he said he had not run the car down the track n thats fine and dandy... I have no problems with the entire deal... He got the better end and that is clear... That is not the reason I came here... I was not trying to start a huge war over all this just wanted him to be clear about the mustang thats all... And in My Opinion he Imbellished quite a bit on the Camaro as well... In My Opinion he knew the car would not run what he said and he knew about all the leaks and so forth as well but thats just My Opinion. We took that chance when we did the deal... And thats just my two cent's worth!!! Thanks for everything guys... |
The cage actually looks a ton better than the one in the mustang. 11.99 thats funny....it had half the enging last year and went 1/2 a second faster at 118 mph..... the guy tuning it needs to have someone else tune it cause he doesnt know what he is doing.....[/quote] |
I could be wrong but with that big of a converter and roller cam I think the car could use more gear than a 3.90 especially at 3500lbs. I guess if you are wanting a street car to cruise in that would be ok but I still think it would pick up with more gear. JMO
| All times are GMT -8. The time now is 04:56 PM. |
