it already outgrew my hair
let me fix this mopar and others who said this nice job :lol: :lol:
most guides have a few thousands of play unless the heads are new or near new or have had the guides replaced. Find someone to help u go threw a entire engine.
im going to go threw the whole thing
i know there should be some play but there is ALOT in a couple of these guides, im takin the heads to the machine shop tommarrow to get new giudes installed and another valve job done thanx so much to yall who helped me figure this thing out |
dont take it to the same one that did those heads
dont take it to the same one that did those heads |
im not
You said this engine had 1200 miles on it...and you say ANOTHER valve job,so I assume you had the valves ground when you built the engine...How did they not know the guides were bad ?Hard to imagine any competant machine shop doing a valve job on a set of heads with worn out guides.
If you got oil puddled up on top of the pistons, you've got other things to worry about than a wiggle in the valve guides.
JMO>Cp |
JMO>Cp |
| All times are GMT -8. The time now is 12:22 AM. |
