Just out of curiousity, did you run the valves to check that they were set properly?
0.024 on both the intake and exhaust, as per the cam card from Comp. |
Whats the cam specs besides lift ? and where did the actually install it at ?
For it to have that much crank case pressure you'd have to have slim to no vacuum. They are is major issues there, and a good amount of power there also. |
For it to have that much crank case pressure you'd have to have slim to no vacuum. They are is major issues there, and a good amount of power there also. http://i205.photobucket.com/albums/b...int_Sheet1.jpg |
Another interesting fact is that, on the first three dyno pulls on race gas, the crankcase btween 8 and 10 inches of vacuum.
It was only when I switched to alcohol that I started to build crankcase pressure. At times, as much as 29 psi. |
Says its not there, did u delete it ?
I assume you havent raced it yet ? |
I assume you havent raced it yet ? First runs on the new engine tomorrow. Here it is again: http://i205.photobucket.com/albums/b...int_Sheet1.jpg |
Here is a link to the dyno pulls:
The manifold pressure is actually the crankcase pressure. The file name indicates the run number. The forst three runs were on gas, the remainder on alcohol. http://s205.photobucket.com/albums/b...Dyno%20Sheets/ |
| All times are GMT -8. The time now is 04:15 PM. |
