-   -   TIMING ? AGAIN (https://www.racingjunk.com/forums/showthread.php?t=25303)
Tod74 08-19-2009 08:03 AM
Guys, lets get back to the symptoms.
He said at 34 degrees, there was no issue. At 36 degrees, a miss occurs.
A broken spring, pushrod, rocker isn't going to cause a miss with a change of 2 degrees of timing. A broken part will cause an issue at all times, no matter the timing change.
good point.
FullTimeRacing 08-19-2009 09:08 AM
Originally Posted by JEFF69Z28
NO CRANK TRIGGER.
34* IT HAS JUST ALITTLE MISS.UNDER NO LOAD.
36* IT RUNS ROUGH FROM 3000 THRU 5000.UNDER NO LOAD.
I GUESS WHAT IM ASKING IS COULD I HAVE BEEN OF A TOOTH OR SO OFF WHEN I PUT THE DIST.BACK IN AFTER I LOCKED IT OUT?I PUT IT BACK WHERE IT WAS OR I THOUGHT I DID.I WOULD LIKE TO TAKE IT OUT AND REINSTALL IT.TO DO SO WOULD I GET NUMBER 1 TO TDC(0) AND THE MOVE THE BALANCER TO 34* THEN DROP THE DIST BACK IN MAKING SURE THE ROTOR IS POINTING TO THE NUMBER ONE PISTON.
he says here that it has a little miss @ 34*....just saying
OneBadGMC 08-19-2009 09:27 AM
The point being, a miss due to a broken piece of the valve train is typically going to be RPM dependent, and won't change with ignition timing.
FullTimeRacing 08-19-2009 10:16 AM
without looking at the car, you, are myself are just giving best guess.
the video of it running you ask for would help.
I'm thinking a crank trigger would solve the problem ,but that is me.JMO
OneBadGMC 08-19-2009 10:58 AM
I agree on the video.. Without a video, his best thing to do is just start R&R'ing parts until he finds the faulty one.
JEFF69Z28 08-20-2009 01:30 AM
SHOULD I HAVE 2 BATERRIES ONE TO START THE CAR AND ONE FOR ACESSORS,RIGHT NOW I HAVE 1 BATTERY TO DO EVERYTHING,START CAR,RUN DUAL FANS,WATERPUMP AND IGNITION AND I HAVE A 100 AMP POWERMASTER ALTERNATOR CHARGING THE BATTERY.
oldandtired 08-20-2009 06:20 AM
That is plenty. Dave
JEFF69Z28 08-24-2009 08:14 AM
TOOK OUT 6AL2 AND PUT 6AL BACK IN AND IT REVS ALOT CLEANER NOW,NEXT IM GOING TO CHECK THE ROTOR PHASE.
JEFF69Z28 08-29-2009 05:38 AM
went to track car had a stumble on launch started messing with jets stumble started to go away 60' went from 1.52 to 1.47 then ran out of time.one thing i didnt understand was when my 60'dropped my mph also dropped why is that?
wmeabates 08-29-2009 03:24 PM
What did you change in the jeting to improve the 60 ft? Give some info about the carb.Bill.
