-   In The Pits (https://www.racingjunk.com/forums/forumdisplay.php?f=18)
-   -   Give up your combo, e.t and mph (https://www.racingjunk.com/forums/showthread.php?t=17220)
dynaguy03 11-08-2008 05:34 PM
1982 CHEVY S10
388CI SBC 13:1-JE pistons
- Comp Cams 640 lift solid roller
- JESEL VALVE TRAIN
- Ported Canfield alum heads
- Super Victor Jr ported
-Eagle H beams and bottom end
- NOS 2 stage- 2 fuel systems holley for Nos - Aeromotive for Motor
- PG W/1:80 straight cuts electric shifter- 5:13 gear 14.5 x32
-dyno'd @ 632hp 599 ftlbs 2900 w/0 driver
Best Motor- 10.01@ 131 1:39 60ft
Best NOS- 9.30@ 144 1.31 60ft
russ67chevelle 12-10-2008 04:24 PM
572... ALL DART(I GOT A SUPER VIC THIS NEXT YEAR TO TRY) 10 TO 1 COMPRESSION...67 CHEVELLE 3000 LBS GOING DOWN TRACK IN HIGH GEAR WITH 15% CONVERTER SLIPPAGE(GOTTA TALK WITH CONVERTER GUY) WENT 8.66 @139 WHEN I BACKED OUT OF IT CAUSE IT WAS MISSING ON TOP END, ABOUT THE 1000 FT MARK ROUGHLY.THINKIN I WAS HITTING 7600 CHIP. 275 SHOT NITROUS :twisted:
355 CNC DARTS,286/296 @ .050 ON 112.7/4 SWAP COMP CAMS 321 336 TOTAL DURATION.(I THINK ITS ABOUT 10 DEGREES TOO MUCH @.050).BIG SHOT PLATE,1150 THREE CIRCUIT WITH STOCK JETS AND POWER VALVES. TURBO 400 BRAKING MOTOR TO ABOUT 32-3300 RPM.NITROUS ALL IN WHEN BRAKE IS RELEASED.4.11 GEAR 33" ET STREETS
http://www.dragstuff.com/forum/viewt...t=15&start=690
CHEVELLE PICS,SORRY I COULDNT FIGURE OUT AN EASIER WAY...
http://www.dragstuff.com/forum/downl...e3d1&mode=view
bigb2709 12-17-2008 05:54 AM
1967 all steel camaro, stock body, leaf springs w/ slapper bars, 10x28 goodyear eagles, non ported steel head 406 sbc, flat top pistons, crane solid camshaft, powerglide w/ brake, 4:56 gear, small shot NO2. I went 10.30 @ 128 with 1.40 sixty ft. on the motor and a 9.76 @ 137 with a 1.32 sixty ft. with a small spray. I know its not too quick by todays standards but I did this back in 1990. Back then this wasn't too bad 8)
slowmotion 12-17-2008 05:02 PM
Very mild 468. 450hp 532 ft/lb. 'glide, 9" 4.56 gears. Wrong converter. Stalls at 5100 supposed to be 4000-4500.
1.34 60'
6.27 107mph 1/8 mile.
Just got the converter tightened up. Gonna make some test passes in the spring and hopefully get regeared for 1/4 mile.
Scotty2 01-22-2009 09:46 AM
Originally Posted by radicalz
Originally Posted by Scotty2
Went a 8.239 @ 164.276 this past weekend .Track wasn't that great ...... they wouldn't spray passed the 100' mark and the car was skating when I would pull high gear.
.....Sweet ride Scotty....Ford powered or Chevy Powered....either way it is flat out flyin...good job.....had mine outy again this summer mad best pass off the bottle 10.34 @ 134.65 mph....did not do the bottle yet added another system...hehehehe.....best with the 300 plate was 9.85 last year.... working the bugs out of new system b4 blasting down the 1/4 mile....maybe in the spring i can rake it one time.... :wink: :wink:
Sorry I didnt see this before today it's a 598ci N/A FORD with a glide
nofear57 02-03-2009 09:52 AM
Hey Scotty2....very cool car! Which tracks have you raced at?
TopspeedLowet 02-03-2009 10:04 AM
Bracket door car
Beretta Door car 25.4 chassis, 582 tall deck Chevy, all motor on gasoline, 12 degree profiler heads ported by Steve Schmidt inc, single dominator carb 1400+ cfm, engine is NOT MILD at all. TH 400 trans with 2.10 first gear hand shifted to a 3.90 rear gear and 102" roll out D1 good years. 2360# runs 7.62 ET at 180 to 187 MPH, 4.82 1/8 at 146.5MPH, 60' 1.090 in 3200' corrected altitude. Bracket race at the midmichiganmotorplex in Stanton MI, in the no box class. (I do not run for points, just satisfaction). My wife and I are the whole crew and she video tapes every run from the stands. drivingmissDD has VHS video of 64 passes I made in 08.
Hoping to blow the chassis sticker off the cage this year, expecting 7.49 ET at 187 in 09 or else..........
Scotty2 02-03-2009 01:13 PM
I've had it to TMP,Reading, Sanair.Naperville, Atlanta, St.Thomas,Luskville
nofear57 02-03-2009 01:48 PM
I guess Gimli Man. is a little far to come,thats an hour north of Winnipeg. I've raced there and their track is great. Its 700ft above sea level and usually good air which makes for some quick times.
superstreeter 02-04-2009 10:32 AM
Well too much time on my hands lately...lol
75 Pontiac Firebird
588 Brodix aluminum
11-1 comp, pump gas
roller 270/280 750 lift
357 afr cnc heads
1250 cfm w/s.victor
2 speed glide ts built
4.56 gear w/ 31x31 et street
2850 track weight
9.37 @ 143 1.36 60'
200 shot of the bottle shud get me a 8.50
and thats it,,time to quit..lol
nofear57 02-04-2009 11:31 AM
:shock: ya right.....a 200 shot will lead to a 250 and then a 300,lol :lol: Just remember once you start it'll be hard to stop!
Your rear tires will be recording the 660 timer and Blair's going to love that! Can't wait to see those tail feathers fly 8)
Scotty2 02-07-2009 12:29 AM
Sounds good, but I think I'd need to pack a lunch for that trip :P
nofear57 02-07-2009 06:20 PM
Peanut butter and honey sandwiches are great for a long trip. The peanut butter will stick to your ribs and the honey will increase your energy,lol :lol:
Ya it would be a bit of a drive. I would love to race at some southern Ontario races when the big boys are there to,but ya,its just to far to go. Like our Canadian Anthem says "far and wide"!
chevyfireball 02-20-2009 02:17 PM
This is my Tommy Mauney 67 Chevy 11 Nova.
632ci Dart Big M block. 18 degree Dart Heads, 2x 1050 Dominators (flowing 1220cfm). Two speedtech nitrous systems (400hp off the line, another 300hp real soon after). 4 stage dry sump pump. TCI Powerglide. Neal Chance aluminum convertor, MW 9.5" diff. 4.10 gears. 40 spline gundrilled MW axles
60': 1.06 1/8th: 4.44 @161mph; 1/4: 6.84 @ 198.09
I currently have the New Zealand Et & Mph record for a nitrous car.
http://www.kiwidragracing.com/multim...s/DSC01884.jpg
Scotty2 02-22-2009 02:07 PM
Thats gettin it done ^ :P
harben 03-26-2009 04:30 PM
120 inch altered
120 inch altered best et of 8.48 at 156. 1.10 60 foot
car weight 700 kgs 1540 pounds
0010 block 3.48 GM steel crank, 6inch eagle rods, SRP 13 to 1 pistons AFR220 heads, roller 625 lift cam 70 pound rev kit, 220 pound seat valve springs, edelbrock ram with enderley hat injection 80A pump, 58 main pill no hi speed
stock case powerglide, 172 1st gear, 6000 convertor, alloy head strange 9inch with 4.56s on 32 x 14 x15 slicks
belive there to be 2 teenths still in it onb a hotter turn. engine got 400 passes on it now, with only a couple of hones, and valve laps!
Cheap racing!!
nofear57 03-26-2009 06:19 PM
harben can you post a picture of your altered,I'm interested in what it looks like.
Here is mine.
http://static.racingjunk.com/63/ui/3...9882427281.jpg
DALACHEAX1 04-03-2009 08:19 AM
Pontiac Sunbird setup
406sbc,Sonny Bryant crank,GRP Alum. rods,AFR 227 Heads,.737 lift roller,950 carb,150hp plate kit,Probrake Glide,8in 4800 converter and a 9in w/4.56 gears.
2800lb w/driver 1.34 60ft,3.785 330ft,6.15 1/8th at113mph,and 9.77 at 137mph in the 1/4 mile.
Changing setup somewhat may get into the 5's tonite!!
http://s683.photobucket.com/albums/v...s%20All%20Out/
DALACHEAX1 05-11-2009 07:10 AM
New best at Pinks All Out Memphis!!! 9.53 at 140 mph!
JEFF69Z28 07-13-2009 04:57 AM
86 SS MONTE CARLO ALL STEEL EXCEPT HOOD,3485 WITH ME IN IT
406 SBC, COMP CAM,AFR 210 ELIMINATOR HEADS COMP.PORTED.
PRO SYSTEMS HOLLEY HP CARB 840 CFM,SUPER VICTOR PORT MATCHED
8.5 WITH SPOOL AND 4.56 GEARS
ATI 8 INCH CONVERTER
TURBO 350, 28X9X15 M/T SLICKS.
WITH A LITTLE TIRE SPIN SHE WENT 10.47 @ 128 MPH
ssaa7931 07-29-2009 10:14 PM
big inch motors
615 cubic inch chevy in my s/g davis vette 9.90 @172mph and same combo in my s.c dragster 8.90 @186mph
cepx111 07-29-2009 11:38 PM
Show that nice looking pontiac off man.
Never mind, I did it for you.
http://i683.photobucket.com/albums/v...0Out/002_2.jpg
Chow>Cp
Scotty2 08-10-2009 01:00 PM
Just ran a 8.20 @171 @ Sanair Quebec .Track wasn't that great.Had to peddel every pass
JEFF69Z28 09-15-2009 07:00 AM
CARB ADJUSTMENT SHE WENT 10.38
bluenova71 10-12-2009 03:20 PM
nova
'71 chevy nova stock suspension all steal but the hood 406 sbc eagle crank scatt rods trw flat tops jegs 215cc heads crane sollid roller victor jr proform 850 tci 8 inch 4800 stahl pg 1.82 low gear went 10.700@124mph on 93 octane and no transbrake
JEFF69Z28 11-24-2009 08:47 AM
Re: nova
YOU MIGHT GO FASTER WITH A TURBO 350
10secbu 11-26-2009 05:49 AM
1979 Chevy Malibu.
home built 582 bbc, conventional headed
Rossler 1.80 terminator 5 glide
4.11 gear 12 bolt rear
Hoosier 295/65 DOT D/R tire
stock suspension (bolt-on upgrades)
Still sorting through some hook/power management issues.
Best run this season was an 8.53 @ 159 with a 1.24 60' at 3258 lbs w/driver.
Oh yea, ALL MOTOR.
mrharris 12-15-2009 06:40 PM
topsportsman camaro
1992 don ness camaro 600in big chief drysump 2 terminators on hogan sheetmetal intake 2420 with me in it tsi 5500 powerglide tsi spragless converter 8 passes on everything since new WITHOUT SPRAY 106 sixty foot time with 479 at 148 on decent track have 3 stages on it but waiting to break the motor in :twisted:
dynaguy03 01-07-2010 10:46 AM
Dragster Newbie- had a 10.20 door car and switched to a dragster .
04 DRAGSTER..Mild 582 bbc - 13-1 -1050 APD DOM-DART 360 HEADS INTAKE, BIG M BLOCK, Power glide - Strange rear /axle's--nothing exotic... 1.07 60ft runs 7.58 @ 179-180
vegaracer990 02-24-2010 08:26 AM
My Combo...
355ci, worked Brodix T1's, 750 holley, 13 to 1, 1 7/8 stahl headers, 1.76 glide/brake, 9 in., ladder bar, 4.11's, TCI 8in, 10.20's @ 130, best of 10.148 @ 131.77 1.444 60ft, 6.447 1/8th, car weighs 2270.
bad68backhalf 01-29-2012 07:37 PM
468,14to1,big brodie heads,737 mech rollor cam ,dart intake,1050 domanater. 400 turbo,5500 conv,dana 60 488. car weighs 2950.goes 9,90s 140 132 60ft
BEAST477 01-30-2012 05:29 PM
My best pass to date is a 8.99 @ 149.05
My Nova is 2870lbs at the line.
I'm running a 540BBC, Dart block, Brodix BB2x heads flowing just over 400 @ .800, Quick Fuel 1250, Reher-Morrison cam .808int .765ex 284/[email protected]
Turbo 400, Hughes 9" spragless conv.
Dana 60, 4.56
M/T 33x16.5x15
