What brand spark plug(s) and what's heat range?
Cp |
New doesn't matter too much if they are the wrong springs. What exact spring brand/part number is in it?
If the springs wind up being correct, then as said before, you're gonna have to either take it somewhere to be checked, or start swapping out parts one at a time until you find the culprit. |
You could have a spring broken. Mine did what you say yours is doing and it had less than 30 passes on some Manley springs I pulled the stud girdle and found one spring had the inner spring broken. Impossible to see without really looking. Just a thought.
Any strange noises while the engine is at idle?
AS OF NOW IM INSTALLING MY OLD 6AL BOX AND MAKING SURE THE MAG PICKUP WIRES ARE AWAY FROM OTHER WIRES THAT CARRIES 12 VOLTS.LUCKLY I HAVE SOME FRIENDS WITH THE STUFF I HAVE SO I CAN SWAP OUT PARTS TO SEE IF THEY ARE BAD. |
If it's broke you will see it when the girdle is off. I was looking for electrical problems too when mine did it.I found a small chunk of metal laying in the head, that's when I took the girdle off and looked at the springs. Mine would do fine free reving and in the burnout box but would start cut out about 6500 rpm going down the track.
Might have a broken push rod. If you are using a stock type push rod I have seen the small round ball on the top or bottom of the rod sheer off.
Guys, lets get back to the symptoms.
He said at 34 degrees, there was no issue. At 36 degrees, a miss occurs. A broken spring, pushrod, rocker isn't going to cause a miss with a change of 2 degrees of timing. A broken part will cause an issue at all times, no matter the timing change. |
| All times are GMT -8. The time now is 09:31 AM. |
