Originally Posted by Tod74
so alcohol is a NO- NO with SRP'S? even without NOS
I'll be buying JE's again next time I build a motor for the simple fact that ARUSSELL is taking the time to educate people when he doesn't have to.
sbc je piston ident
Thanks for your time, I have an what iwas told a 358 chev sbc
i pulled the pan & the pistins say je 521L & 521R ( i assume the sffix is positional) underneath, I cant find that in the catolog, any idea ogf what the are |
Re: JE Piston Tech
Originally Posted by ARUSSELL
I am a Tech at JE Pistons and can help with any piston related issues or questions.
I have a set of JE BBC Pistons that i really NEED to replace the whole set,but was Kicking around a Partial set??? Part # 111721 then below that is 519818 4.375 Bore Heres what is WEIRD?C/H i measure 1.400. Is this a Shelf Piston and can you give me some Pricing? The Combo is a 10.200 T/D BBC Block,it did have a 4.280 Stroke Crank,and a 6.635 Rod. Going to Ditch the 4.280 Crank and go with a 4.250 Crank and a Set of Standard 6.635 Rods,2.200 Big End.The Old Rods are 2.100 on the Big End. I also have 2-of the BAD pistons that i would like to send you for your PROFESSIONAL Opinion,as to what Caused the Damage??? Thanks Greg 8) [email protected] 231 690 5075 cell |
I have a 515 CID motor that is ready to assemble
I wish to make a 540 or 548 procharged motor Block 9.8000 deck BBC 4.000 stroke Bryant Crank 6.358 Oliver rod 4.530 JE Piston flat top with slight valve cut relief & cool coated How simple or difficult will this be or better yet, how many new parts am I going to have to buy. |
| All times are GMT -8. The time now is 01:54 PM. |
