-   -   bad cam (https://www.racingjunk.com/forums/showthread.php?t=20078)
olds48 03-18-2008 02:01 PM
This has been a very .....interesting thread.
Tod74 03-18-2008 04:30 PM
Originally Posted by blittle
Originally Posted by bbc28racing
there lunati hyd. and you have to set big blocks on 0 valve lash.and my rocker arms and nuts were bad.
:roll: Dude, Hyd lifters do not not set at zero lash. Doesn't matter if your nuts and rockers were bad or not.
But good luck with that!
Maybe he was trying to hold the valves open to bleed off compression to combat detonation.... :P
maxpower671 03-18-2008 08:28 PM
stinky
heard detonation is a bad thing? man, this thread has been a stinker..
bbc28racing 03-19-2008 07:40 AM
remember,this is a big block.you cannot turn them a quarter or half round like a small block.the motor will detonate!!
Tod74 03-19-2008 11:05 AM
I think you are trolling....no offense.
bbc28racing 03-19-2008 11:47 AM
no,i'm not trolling.i think it's the other way around....no offence And i had great luck with setting the valve lash on 0.
performanceengin 03-19-2008 12:24 PM
for any hydrolic lifter to function properly they need .040 preload on plunger. that is where 1/2 to 3/4 turn comes in to play.
bbc28racing 03-19-2008 12:45 PM
if it's stock it will work.or on a small block.just ask a big block company.or ect.like brodix,or dart(there also small block)or some big machine shops.on a big block the lifters build up more when you rev them up,so if there 1/4 or 1/2 turn it will be like 1 1/2 or something when racing.also roller rockers and poly locks or hex locks are important.
olds48 03-19-2008 01:09 PM
seized yes springs inside froze and quit oiling kindof like if the were solids,and new ones work good but now are starting to do it too the motor starts popping not loud popping like times too high and laboring almost dieing.can't set past .004 with feeler gauge hydrolic cam 490 like stock cam all stock lobes rockers and springs look good .maybe cams qround wrong :?: can't figure it out.help any?thanks
