You could check the drive shaft Carl. I always put the shaft all the way in the trans bushing and like to have no more tan 3/4 inch back to the rear end yoke. Too much slack will give you a vibration.
Is the rear tranny mount OK? Also do you have solid mounts or rubber? I like to use solid mounts with rubber trans mount. It does give you more vibrations but they won't break. Just my thoughts. |
i call shot gun. o yaa your to dam far away for me to call that. nice job hope it craps the scare in you or scares the crap out of you.
glad to hear ya got it home carl
Less than 24 hours to track time.
I can tell it will be spinning at least through the 60'. :D |
Don't worry its a common problem we all have !!...Good luck and let us know how it turned out...
later Brian |
GOOD LUCK AND CONGRAT'S, CARL :D
AL |
Results are in....I need Slicks...BAD!!!!!!!!!!
I will post more tomorrow, right now I am tired and bed is calling.... |
Like I said Carl, I've got those M&H's..... :D I'm glad that you have that much power!!! Can't wait to hear about your track time, as I won't get to the track until June 9th. :cry:
ok carl wake up and let us know.
Carl its time for some numbers. Wesley
| All times are GMT -8. The time now is 07:03 PM. |
