Re: Parts
Originally Posted by bbchevy
Originally Posted by kod99
Hot leakdown test was even worse. Pulled engine and sent it the engine builder to be checked out.
JMO Zip. I'm gonna put on a 0 1/2 pump, 80 pill and 39 nozzles and tune from there. Hope things are NOT to bad,and maybe a Finish Hone and a set of Rings.....? Later G |
i was told of a good way to stop milky oil and help get temp up :wink:
an old timer told use to run a vac vent line from the manifold in side the car with a valve on it .... this way when you open it.... it sucks air to lean it out and will get the temp up as well. he also said to get the temp up to 200 deg. before shutting the car down :) |
The engine is apart.
Thankfully, no big damage. The ring gap was a bit big on some cylinders. Gonna replace the bearings, because they were a little washed from the excess alcohol, and install some gapless rings. |
an old timer told use to run a vac vent line from the manifold in side the car with a valve on it .... this way when you open it.... it sucks air to lean it out and will get the temp up as well. he also said to get the temp up to 200 deg. before shutting the car down :) I have a lean out valve on the car and I used it when the engine had a carb on it. With the injection, I just pull out the fuel shut of until the engine is lean. |
Look into rings from Wiseco or JE, low tension, there is hp in that area.
Did they say what the ring gap was ? |
Did they say what the ring gap was ? I'm gonna go to gapless top rings. Changing to a Sniper manifold at the same time. It will be a couple of weeks yet. |
Did they say what the ring gap was ? I'm gonna go to gapless top rings. Changing to a Sniper manifold at the same time. It will be a couple of weeks yet. Which intake manifold are you running with your injection system? |
| All times are GMT -8. The time now is 02:59 PM. |
