-   -   retired mechanic is going racin'!!!!!!! (https://www.racingjunk.com/forums/showthread.php?t=28170)
mwbrasher 10-27-2011 07:21 PM
do you think 5:13 are to deep? maybe i should go with 4:56??? i was worried about not enough h.p.... on dyno only 268 lbs of torque.... thanks... 8) 8) 8)
spib 10-27-2011 07:35 PM
If your going to stay with 28 tall slicks a 4:56 gear would be good
your vega would like a loser convertor
I used to have 29tall slicks with my 4:86 gears I was at 7500 on chip
same slicks same gears with old motor was at 6,000 rpms ran 12.70 mostly stock 355
my convertor is a 8" ati was around 4300 with 355
stalls now at 5400 with my 385
run it and get used to car make small changes and have lots and lots of fun!!!!
mwbrasher 10-27-2011 08:05 PM
hi spib.... i'm running a 14x32x15 rear tire... turbo 350 trans and 5:13 gears....thanks... :lol: :lol: :lol:
zipper06 10-27-2011 09:27 PM
There's a couple changes you could make, (now these are just from my experience running sm/blks) A 331" motor doesn't need that much tire, you could probably run a 10.5 or 11" tire X 30" tall and improve ET and 60' times. if you're going to stick with the 14X32's i'd go to a 5.86 gear, it won't help your 60' time much but it should improve your ET some, you have to spin that motor pretty high to make it run good. I run a 377" motor with 14X32's and a 5,43 gear, it runs high 1.40's 60 ft and 10.50's @ 125 mph, i'm running around 7400 RPM in the qtr. in a 3250lb car, but i'm also running alcohol.
curtisreed 10-28-2011 03:32 AM
hi there as far as i know tulsa raceway runs 1/4 mile ... that will be our home track. thanks ..caveman53 :shock:
I just saw that you are racing Tulsa. That is where I race also. I might have seen you there. What does your car look like and where are you from?
Curtis
P.S. It looks like we might get a few more years to race there now.
spib 10-28-2011 05:02 AM
I have 32x12 slicks now and my rpms are way off
i now am 6750 at the finish line , Im going to a 5:13 gear next yr myself
but last race still ran a 10.56 at 127 even with the softer gear
mwbrasher 10-28-2011 07:45 AM
hey doorracer.... i have a little primer grey vega.... still in the "worki'n out the bugs" stage... what do you drive?..... caveman :D :D :D
mwbrasher 10-28-2011 07:52 AM
hey spib.... i went with the 5.13 because i was going to build a 383... a freind of mine had this engine. 331 11:5 comp.... old 365 hp type corvette motor... so...... i thought i would put it in this summer and have some fun!!... i have a 350 4bolt main i am going to build hope to make more power....i spent a lot on the eng back... but a low dollar eng for this summer.... next year!!!!!! thanks... caveman :D :D :D
curtisreed 10-28-2011 10:15 AM
Here is me.
http://i242.photobucket.com/albums/f.../zDSC_0063.jpg
mwbrasher 10-28-2011 01:17 PM
hell yea... nice ride ... i've seen you there... next you and i are at the races i'll swing by and shoot the bs... thanks caveman :D :D :D
