Actually i did better then this..i wiped Anti-seize on the outside collector ( might want to take them off one day)...reason they were so tight is the collectors had been thermal coated making the OD a little larger then un-coated.
Grease would have worked pretty good going on,,,but not much help when you want them off after running them for a season. :shock: |
| All times are GMT -8. The time now is 11:27 AM. |
