David,
looking at the difference in torque values between the last motor and this motor, you might benifit from a little tighter converter, maybe 5500 to 5800. I think i read somewhere you were running a 6200 stall. Nice numbers though for sure. JMO Zip. |
Originally Posted by BEAST477
You gotta be pleased with those numbers. 8) See ya at the track tomorrow.
Originally Posted by zipper06
David,
David,
looking at the difference in torque values between the last motor and this motor, you might benifit from a little tighter converter, maybe 5500 to 5800. I think i read somewhere you were running a 6200 stall. Nice numbers though for sure. JMO Zip. Zip. |
David,
looking at the difference in torque values between the last motor and this motor, you might benifit from a little tighter converter, maybe 5500 to 5800. I think i read somewhere you were running a 6200 stall. Nice numbers though for sure. JMO Zip. Zip. I'll have some track results today I hope :D |
Update you guys on the long rod and compression
Dyno Results very good ... track results its worth slim to none et wise but have seen mph difference. I was told the long rod would look good on the dyno, so far its been 7.52@179 mph I've swapped headers and 4 different converters, msd digital 7 along with coil, back tires, shift points, launch points .. all has changed nothing. |
I think the long rod motor creates a little more torgue, but would not be as evident on a light car such as a dragster, SO a tighter converter just might show improvment on the ET. I know you like to run a loose converter to keep the violence down in the first 100 ft.. Heck i'd put a 5500/5800 in it to see if it changed, the compression is not going to help on the top end unless you're running 8500 rpm.
JMO Zip. |
Thanks for the reply zip .. tight converter is slow and more often then not in the dragster it will be. I tried 5400/5800/6200/6700 stalls already, 6200 fastest 6700 next fastest. 5400 by far the slowest.
Well guess you got me on that one, since you've been there. I'm more used to the high winding sm/blks and lower geared rearends.
Zip. |
Hammertime, you seem to be on top of things with the horsepower and compression deal, so I would like to ask what you think. I ended up with 13.3-1 instead of 15-1 compression. I wanted to know about how much power difference do you think that is. It's a 632 with Dart Big Chiefs and two dominators. The cam is 284in-304ex @ .50 on a 114 LC. The pistons are shipping out on Monday so I can still change them if need be. Thanks
| All times are GMT -8. The time now is 03:02 PM. |
