Can you give us exact,step by step instructions as to how to make that popcorn? 2 Place in microwave and heat for 3 min. ( DO NOT BY ACCIDENT HIT 3000. AND LEAVE THE KITCHEN) I did this one time. I actually went to take a dump and hit 3000 on the micro wave. When I smelled the popcorn burning I hauled ass to the kitchen to find one hell of a fire in the microwave. The smell of burnt popcorn was so bad I almost had to leave the house and stay at a motel. I had to throw the microwave away and it was a christmas present I got the day before. (Stupid is all I can say):oops: It took weeks to get that nasty smell out of my house. 3rd. Open bag away from body. Contents may be hot. (No schitte) |
Originally Posted by Tod74
Originally Posted by suicidebomb
Originally Posted by cepx111
Originally Posted by kwkracing
If your in doubt go back to a hydrualic and leave it alone
Valve lash threads, never fail to bring a few grins........It's almost a tradition. Would anyone like some popcorn? BWAHAHAHAHA http://forums.racingjunk.com/viewtop...er=asc&start=0 Nope, I do it the wrong way. :) |
valve adjust
thanks rabbit. maybe i was only going .002 loose now that i think about it. in any event i will adjust just as you say with the .002 number(looser) this sound just right and i am sure others will agree with this. its amazing how different metals respond to hot and cold art
Originally Posted by sc4405
Originally Posted by traysvega
I've always adjusted them this way.Hot.
pop the distrib cap rotate(bump) motor to no. 1 on cap.Set balancer to TDC 0....Adjust both intake and exhaust for no.1 cylinder Rotate counter clockwise 90 degrees or 270 on balancer and set both for no. 8 Rotate counter clockwise 90 degrees or 180 on balancer and set both for no.4 Rotate counter clockwise 90 degrees or 90 on balancer and set both for no. 3 Rotate counter clockwise 90 degrees or 0 on balancer and set both for no. 6 Rotate counter clockwise 90 degrees or 270 on balancer and set both for no.5 Rotate counter clockwise 90 degrees or 180 on balancer and set both for no. 7 Rotate counter clockwise 90 degrees or 90 on balancer and set both for no. 2 Rotate counter clockwise 90 degrees or 0 on the balancer and your back to no.1 again... :wink: Button on firewall. and maybe 10 minutes. I actually this weekend before the going to the track tried this...first my way HOT....Had 2 valves only a very very small amount loose..adjusted...Then second ran it again HOT and did the EOIC method....not one valve was different from my first adjustment.Not sure but my way works.I've done this long ago with the same results on a older cam profile roller with no difference so I continued on this fairly new profile (Crower Ultra action Roller).Not sure but think I'll continue with my FAST and efficient adjustment..Also if cold lash setting was the best way to do it,wouldn't you think ALL the cam Manufactures Cards would read "COLD LASH SETTING"....Instead of HOT ... :roll: make yeah go hmmmmm... |
I think 6 people could check 'em right now and still adjust 'em a little. In other words, I like it now go racing and have fun. :D
Re: valve adjust
After you have adjusted the valves hot you should be able to check them cold and use the setting as a reference point. It should be tighter due to the different expansion coefficients in the engine (Heads, block, rockers. valves, lifters, cam, pushrods etc,). Once you have the cold setting you can set them hot or cold. Just annotate the value on your cam card.
[ it,wouldn't you think ALL the cam Manufactures Cards would read "COLD LASH SETTING"....Instead of HOT ... :roll: make yeah go hmmmmm...
pop the distrib cap rotate(bump) motor to no. 1 on cap.Set balancer to TDC 0....Adjust both intake and exhaust for no.1 cylinder Rotate counter clockwise 90 degrees or 270 on balancer and set both for no. 8 Rotate counter clockwise 90 degrees or 180 on balancer and set both for no.4 Rotate counter clockwise 90 degrees or 90 on balancer and set both for no. 3 Rotate counter clockwise 90 degrees or 0 on balancer and set both for no. 6 Rotate counter clockwise 90 degrees or 270 on balancer and set both for no.5 Rotate counter clockwise 90 degrees or 180 on balancer and set both for no. 7 Rotate counter clockwise 90 degrees or 90 on balancer and set both for no. 2 Rotate counter clockwise 90 degrees or 0 on the balancer and your back to no.1 again... :wink: Button on firewall. and maybe 10 minutes. I actually this weekend before the going to the track tried this...first my way HOT....Had 2 valves only a very very small amount loose..adjusted...Then second ran it again HOT and did the EOIC method....not one valve was different from my first adjustment.Not sure but my way works.I've done this long ago with the same results on a older cam profile roller with no difference so I continued on this fairly new profile (Crower Ultra action Roller).Not sure but think I'll continue with my FAST and efficient adjustment..Also if cold lash setting was the best way to do it,wouldn't you think ALL the cam Manufactures Cards would read "COLD LASH SETTING"....Instead of HOT ... :roll: make yeah go hmmmmm... I've personally done it both ways. BUT, I never will adjust them HOT again sense I figured out I can do it just as accurately using the cold method. Go ahead burn your fingers, do a rush job, make a mistake, see if I care :wink: |
[quote="cepx111"][quote="traysvega"][quote="sc4405"]
te] Some people like to get their fingers burnt and be in a rush, some dont.
| All times are GMT -8. The time now is 03:53 PM. |
