-   -   Oil pressure (https://www.racingjunk.com/forums/showthread.php?t=26753)
stickboy331 12-20-2009 07:18 AM
here is were all the oil plugs go in a small block mopar. 2 behind top timing gear some times coverd by cam retaner plate, or cup plugs. rear of the lifter galleys. one is on the outside right bank. left side is on the inside can be seen through the distributor hole with a mirror. like olds, pontaic v8. plug under oil filter plate 3/8 npt. these last two have ben left out many times there is a seperation plug that goes in the vertical passage from the oil pump, this plug directs oil to the filter, sometimes this plug cannot be removed. this is the same as sb chev.this plug is left out all the time on sb chev. i think all the new sb mopars are the same as old style far as oiling goes. i did see one sb style v6 that was cracked from main bearing to the cam stickboy331
THERATTLER 12-20-2009 07:31 AM
good info ,alright , mark , get busy looking :D
zipper06 12-20-2009 09:10 AM
:idea: Drop the pan, take off the oil pump, make an adapter and put an air hose to it with a leak down tester, it may be messy but once the oil is cleared out you see where all the air is going out.
mopar1968 12-20-2009 01:25 PM
Thanks guys let's see what happens.
THERATTLER 12-22-2009 05:45 PM
Hey Mark , any luck on the 318 yet?
mopar1968 12-22-2009 06:05 PM
Nothing yet still digging !!
mopar1968 12-27-2009 06:38 PM
Well folks found problem, At the rear of lifter galley right rear, has a I call it a small casting hole, Used air and heard it hissing, hard to find but felt air coming out, used mirror and oil sprayed on mirror, Thank all you guy's for your input, now to replace the block, owner agreed to pay for block and i get to build it, Again thank's :!: :!: :!:
''JUST MY TWO CENT'S WORTH''
TheYellaBrick 12-27-2009 06:49 PM
YEEEHA !! Man we can ALL learn a trick or two or three on here, HUH ?
Question; would that casting flaw have been found if the block had been magged ? I mag EVERY block I build no matter if was running leak free or not.
A prob like Marks is the very reason I built a run-in stand...Find the issues before ya stuff 'em in.
stickboy331 12-27-2009 07:13 PM
can you make a sleeve or plug to slide in to the oil galley ,block off the galley before the leak? if the leak is in the right spot :idea:
mopar1968 12-27-2009 09:19 PM
No not where it is at, Double D I had it on a engine run stand thank god, I always run them before installing them cut's down on headaches :lol: :lol:
