-   -   Choosing a BIG Cube BBC Street Engine (https://www.racingjunk.com/forums/showthread.php?t=26201)
hammertime 11-01-2009 09:46 AM
Originally Posted by nofear69
I guess when I first started this thread I was concerned about harmonics and ware and tare in a big cube(crank throw,rod length,length of piston). I'm not up on this kind stuff and was wondering how it would live on the street. A 598 short deck just came out not to long ago and wow that sounded like the answer but once a guy started thinking about it would it survive on the street or would it eat itself alive?
My motor shop dislikes the 598 short deck motor he just doesnt think they will last.
nofear57 11-01-2009 10:10 AM
Ya I don't know anyone that has a 598 short deck,never heard any feedback yet,they're new. I don't want to spend 10 or 12 grand and find out she'll fly apart. I guess I should phone the shops that build them and see what they have to say. I know Dynoflo and Shafiroff builds them anyone else?
DirkaDirka 11-01-2009 10:46 AM
Here is a thread about Dynoflo engines. It also contains another thread about them also. Just read the threads and make up your own mind on them.
http://forums.racingjunk.com/viewtop...er=asc&start=0
TheRabbit 11-01-2009 02:28 PM
:shock: here we go again.. :lol: :lol:
For a street motor I would stay with a 548. Mostly because it is a very cheap ( and good) big cube buildup. And It makes a ton of HP and torque.
nofear57 11-01-2009 03:17 PM
So explain the set up on the 548?
hammertime 11-01-2009 03:22 PM
I am sure Sunset has done one or 2 before, maybe Nesbitt
dont waste your quarters calling the jokers above ;)
hammertime 11-01-2009 03:27 PM
4.25 Stroke 4.530 Bore with 6.385 Rod .. very popular motor in drag racing, they seem to make very good power and it'll be one bad ass street car with that motor in there.
My thoughts on crank and rods ... I run 1000hp on motor and will spray upto 300 with the spray, Eagle has worked good, I now have K1 Rods just to try them, and have good luck so far. I had a 548 once .. it made 850hp (950 on some dynos) with 10:1 compression until it broke a oliver no bearing wear just flat broke the rod in half but the callies magnum crank went with it along with the rest of the motor. Back to eagle for me ... no matter what you use, its only as good as the machine shop doing it for ya ;)
Tod74 11-01-2009 04:25 PM
I have a 540 in mine 4.5 bore 4.25 stroke with a 6.385 rod. Brodix 2x heads I love it. But I don't have much to compare it to as befre this I had 2 406's and one .030 over 454
I will neeeever go back to small blocks. ever.
bjuice 11-01-2009 06:24 PM
My old 511ci and your 540ci Tod ran very similiar..almost same engines. yours had a little more Bore..non the less..they are stout running motor's...not something i would try a long day on the road with the family.
My Best ET with that 511ci was a 5.82et full street trim @3200 lbs..NO NOS all motor.
Tod you put a 300 shot on that 540ci and watch her holler.... :shock:
below is my 1st 5.99 pass in street trim....yeeee...ha.....the next clip is thanking My Northern pitcrew Tom Mc dunnah,,,lol
http://i210.photobucket.com/albums/b...h_100_0263.jpg
http://i210.photobucket.com/albums/b...h_100_0262.jpg
Tod74 11-01-2009 06:28 PM
Give ME a 300 shot and You can watch me holler while I pick up pieces of piston off the track...
I know you used to drive that camaro on the road...can't imagine you do too much of that if any with the nova...do you ever miss having a "hot rod" to cruise to the local Sonic or whatever?
