-   -   Starting Issues (https://www.racingjunk.com/forums/showthread.php?t=20973)
duswill 07-28-2008 04:54 AM
I had the same problem. I installed a MSD Digital 6 and and to date have not had the problem again.
482 11-11-2010 05:08 PM
Hammertime, just wondering if your problem ever recurred or did the starter fix it permanently ? Mine appears to be doing the same thing while restarting.
It will spin like crazy until I hit the ignition switch then starts to drag.
(Also a Tilton starter)
Thanks
hammertime 11-12-2010 04:13 AM
I've never had a problem sense, I had my tilton gone through again at local starter shop, put it back on and it works ok now, he changed a few things in there. I still say it dont work as good as my cheap starter I got from him.
Check for voltage drop first and once you rule out voltage is not a issue look at the starter.
482 11-12-2010 02:34 PM
Cool ! Thanks
I will check the voltage.
Do you still have a drop in voltage going back
To starter?
One last question, did you end up wiring in the
Starter saver too?
hammertime 11-12-2010 07:25 PM
I do have voltage drop but not much. Your looking for a major drop while cranking, ign on and off back there. I ended up buying a digital ignition and pulling 8 degrees out also. Starter saver would work also, i've used them in the past.
482 11-14-2010 05:07 PM
thanks David !
Got a starter saver on the way. 8)
