-   Show Off (https://www.racingjunk.com/forums/forumdisplay.php?f=12)
-   -   The Mastodon (https://www.racingjunk.com/forums/showthread.php?t=19573)
NorthMotorSports 04-21-2008 04:51 PM
Hey man like it says below Im Strange Maybe Even Crazy Buts There Never A Dull Moment lol :lol:
olds48 04-23-2008 12:34 PM
:D I like your top qoute the best. :D
NorthMotorSports 04-24-2008 11:40 AM
Ya ive helped the enemy die for there country a few times in iraq so I figured id put it in my qoutes
olds48 04-24-2008 01:26 PM
Thanks alot,bud.I mean it.
NorthMotorSports 04-25-2008 09:14 AM
Hey listen man it aint no big thing its just what I do 8)
olds48 04-25-2008 01:51 PM
Nah,man.It IS a big thing.You and your kind keep the chicken-hearted guys,like me,who never sign up,FREE.It is a big thing and a BIG sacrifice and this is a BIG thank youTHANK YOU
NorthMotorSports 04-28-2008 10:54 AM
Well its my pleasure man and your prolly smart for not joinin ive seen alot of shit that I really didnt wanna see but I geuss I knew that could happen when I did join its just what I do for my country
olds48 05-04-2008 01:15 PM
OkaY, i went to the track yesterday and did horrible.I built a scoop to go on top of my carb.Hadn't been running one and wanted to keep the rocks out(has a screen on it) and figured it would run better than just a flat top open carb cruising at 100 mph.Well,it didn't work so good...sorta.The air temp was 3 degrees cooler than last time out and I figured that it was not enough to jet up for.I had 82-84 jets in and 32 degree total timing.Made the first pass with the scoop and it started breaking up at the top of first gear and popped all down the track.Pulled the plugs and 6 of them were dead lean and 2 of them(no.7 and 2 were pig rich Looking at the manifold 2 and 7 are the farthest from the carb so you'd think it wouldn't be.Thought I might have got a couple dead plugs so swapped my old ones back.Those two stayed dark for the rest of the day.Made 5 passes total that day and ended up with 96-98 jets and was still lean!!But my 60' started dropping,from a 1.56 on down to a 1.66.I THINK what might be happening is the scoop is ACTUALLY working to force air and is moving enough extra air at the bigend that it is going lean,but jetting to compensate for the big end is making it fat and lazy on the line.But then again,it DID pop as early as the top of first gear twice.I don't know.Also,I have rear jet extensions but not a notched float,I know,I know.And also noticed that between staging (which is pulling up about 200 feet ,shutting down once and then firing up and go straight to the water box,shouldn't burn much fuel)burnout,make a pass and then the return road I am using right at 3/4 of a gallon per pass and coming up with white plugs!!But,moving that much fuel on a single pass,plus rear float probably not dropping like it should,I wonder if I'm sucking the rear bowl dry and getting my lean fron that.Didn't think to try jetting up the front only to test that idea.Got excited Et dropped from 6.93-7.0 to 6.99-7.13 BUT mph went up almost 2 full mph.Really feels like shes is CHARGING 1/2 track on.I can actually feel the car nose down when I let off at the line.Oh,well.Any suggestions?That is if you don't fall asleep reading this.Kinda got carried away.Will put pics up of the scoop I built if I don't sling it over the hill first :evil:
v8Fiero 05-04-2008 01:51 PM
if it is a scoop without a rear air bleed you might be getting too much boost. like if you put a turbo on a carb that is designed for NA. do you have anybody that you can borrow a blow-thru carb for for a day? Im not familiar with how to modify them for blow-thru but that might help if you want to keep the same scoop.
olds48 05-05-2008 04:43 PM
I never knew that scoops had rear air bleeds :shock: It's actually one I built myself,so I'm ure it's not dyno-proven :D Thanks for the idea,though
olds48 06-05-2009 04:21 PM
Whats up fellas!? Long time,no see...type...read...? :? Anywho. Hope to hanging out here again sometime soon. Just aint had much free time. I see all my pics have disappeared. My imageshack thingy went screwy and my lovely girlfriend aint fixed it for me yet. :roll: women :roll: :lol: Need to get that figured out so I can show off( oh yeah,like im the only one here with too much ego in my car :D ) Been busy with the suspension and finally updated the front end. Got a smoking deal on a complete fox body tubular front end from a buddy( aerospace 4 pistons discs,aluminum hubs,adj qa1 struts and tubular k member and arms) and also updated my rear to discs. check it out 91 lincoln town car is a direct bolt on to an early mustang/small ford housing end!!! Rear discs at a total cash layout of $185!!! PROPS TO WAYNE AT QWIK TIME PERFORMANCE , (roanoke,va 540-206-2597) That little setup saved me 225 lbs off the nose alone and now can actually get away from the factory 5 on 5 wheel pattern...oh,and safer braking. Also built a new steering column to attach to the mustang rack(duh,obvious i know) so no more aluminum foil squashed up in the splines of my aged steering arm to reduce the slack on the steering box. NOTE: i mentioned this report on my STUPIDITY in doing so in order to be able to afford to go racing! DO NOT do somethong as STUPID AND UNSAFE as i did. I AM A BAD EXAMPLE!!!DO NOT FOLLOW!!! :lol: SAFETY FIRST!!! So whats new and what have i missed??? Talk to me fellas!...or do ya'll even remember me??? :cry:
fla1976 06-05-2009 05:26 PM
Mastodon
Good to see you're back. Sounds like you've been busy.
Tod74 06-06-2009 04:09 AM
check out LIVELY'S NEW RIDE!
http://cgi.ebay.com/ebaymotors/ws/eB...m=170328506610
olds48 06-06-2009 09:06 PM
That's not really his,is it? That thing is plum bad
,though!!
Tod74 06-07-2009 07:50 AM
,though!!
:lol: No it isn't his..... I would describe it as horrible
olds48 06-07-2009 01:02 PM
It's not bad...I don't think those are the correct quarter panels for that year model...but,I could be wrong
lively 06-07-2009 05:13 PM
ALOT OF GUYS JUST HAVE SOME SMALL HOLES IN THE REAR OR BEHIND THE CARB ON BOTTOM TO LET OFF SOME PRESSURE
MY SCOOP HAS 3 [3/4 INCH HOLES IN THE BOTTOM LIP BEHIND THE CARB TOP]
[ BUT I KNOW--IT IS A FORD!!!!!!!!!!!]
LIVELY
