Originally Posted by spib
Originally Posted by maxpower671
Originally Posted by greenone60
i have a 388 sbc with ik200 brodix heads and solid roller cam and 13.1 comp and it made 600 hp at the flywheel.hopes this helps
010 block, block filled to water pump,13.2to1 compression all 4340 rotating stuff 210 cnc afr heads, T&d shaft rockers crower custom built for my motor 4/7,2/3 swap cam, big roller super victor intake, pro system 4150 carb Its over 600, and it runs :D |
Brodix IK200, about the best bang for your buck. I'm in the same situation as you with kids budget and all,I got those heads on my 383 with KB pistons and from my time slips the hp with a small cam is right there where you want to be.
How bout 6 kids on a tight budget.
388 eagle assembly with 5.7 rods and KB134 flat tops AFR 220X old heads milled to 48 cc chambers Roller cam (drag race only) alky inj toilet Powerglide 2950lb car 6.29 @ 108 1/8 1.29 60 ft Zip put it together and Zip and some more on here have seen it run. Leave on the converter (5800) and it will ride the bumper for 300+ft Go with what you have. You can find a good set of aluminum heads for around 900 used. Then you have 600 to spend on that intake and carb. Buy a Holley Blue and have fun. |
I found a set of RHS alumiun heads for sale used The guy only want $800 but i havent been able to cross reference any of the numbers on the heads. He says they have 2.02 valves but he didnt know the runner sizes. Plus I think they have had some work done to them. He says "they flow like crazy " but he can't produce any numbers or any info about them. Are RHs heads any good or will can I expect the results I'm looking for from these heads ?
JMO Zip. |
| All times are GMT -8. The time now is 05:32 AM. |
