Re: hey chris
Originally Posted by phillip1320
chris im phillip from Hedman The thing is on hedders for your car is the opel has limited room even though it is a chassis car... and you said you have arms as well if it were a strut front end it would be easier to build. yes i understand your shock as you say about th price but when you count in the cost of materials and welding supplies and a person to build you a custon set on your car for a 18degree motor. it adds up! either us or lakepoint tube chassis would build you a custom set for your car that would have sparkplug clearence and a-arm travel and ground clearance as much as possible with it being a very low opel. chris i hope you find someone to do this but it might be a costly job to have done! good luck chris if you need a kit or just a bunch of bends and flanges ,give me a shout! hope this helps later phillip [/i]
Thanks for replying. and I appreciate the info you gave me over the phone. I guess I did not take into conisderation how low the car sits. I will keep yall in mind though. Again, it was nice talking to you and if I do decide to just purchase the weld-up kit, I will let yall know. Chris |
Originally Posted by bjuice
Originally Posted by zipper06
Chris, you have another option, other than going under the car, you could put a hole in the back of the front fenders and run a combination of fenderwell type headers, we're seeing more of this type setup in the last couple yrs. on a-arm chassis cars, i have a friend who has Baretta with this type setup. The tubes are about 24" long then the collector.
JMO Zip. Chris |
for all the work that goes into making a custom set of headers and have them perfect witch im sure hedman would, I would pay the 1800. jmo
fenderwells.
hey chris depending on the fuel you run... if its methanol, i would go with a fenderwell exit hedder. just so the fumes dont run you out of the car. the opel being a small car with small interior. you would want all the ventilation you can get.so like a lot of other have said on here a side exit fenderwell would be best! methanol is a pain if you cant breathe trying to stage the car!!!!!!
Phillip, do you guys sell a weld up kit that comes out and exits above the running board for a SBC 27 roadster?
Sorry for the Hijack Chris. Oh, and welcome to the forum Phillip. Glad to see people from the manufacturers here. Curtis Reed |
| All times are GMT -8. The time now is 01:38 PM. |
