NO EGT,THE CARB CAME THAT WAY FROM PRO SYSTEMS AFTER I TOLD THEM MY INGINE SPEC'S AND CAR SETUP.THEY SENT SPARE BLANK BLEEDS.IF I NEED TO DRILL THEM WHAT SIZE SHOULD THEY BE DRILLED OR CAN I BUY BLEEDS LIKE YOU CAN BUY JETS?I ADJUSTED THE FRONT SQUIRTER AS I THOUGHT IT WAS TO LOOSE,I TIGHTEN IT UNTIL I HAD NO OR VERY LITTLE PLAY .
Have you tried going smaller with the squirter? Now that you have the idle rich enough, you may be putting too much fuel in with the 50cc pump and .040 squirters. JMHO
Timing… many idle problems are caused not enough timing (with big cams)
| All times are GMT -8. The time now is 07:10 PM. |
