The hardness of that cam will be intresting. I have heard people say the hardness is diffrent in the cams now but I do not know off a test that has been done.Glad it will be from a racer and not a cam company showing the results.
Hey, what i should have said is i have 1 406" with a flat tappet cam, not a roller cam, the other 3 motors are solid roller cams.
About the .002X1/16" wide flat i grind on the bottom half of the roller lifers lets the oil go down to the roller part of the lifter under pressure just as the .015 hole that Jim mentioned that comp cams now put in their special order lifters, Crower now puts the same .015 hole in the bottom of their brand flat tappet lifters. I started oiling the rollers yrs ago by grinding the flats on them. As you probably know it's hard to take the roller lifters apart, so the .015 holes are put in the lifters before assy. I don't have any of those lifters with holes but mine all have flats on them to oil the rollers. Hope that explains your question. I'm going up to Ms. around the 20th of June so i will have some hardness #'s to post. I'll take my laptop with me, i'll also take a solid roller cam with me and and roller lifters and get the hardness on them and post the results of all the tests either on this thread or start a new one about this subject. Maybe even post some pics of our shop equipment. Zip. |
Zip, it does answer the questions. I see you guys talking about things I don't think about or don't know about (yet). I see what you mean about the lifter/grind/holes now... I was just having trouble trying to visualize placement. Man if I could spend just ONE DAY with one of you guys on an engine build.... the school of hard knox is time consuming & expensive sometimes.
X2 Scoot. I'm more of a chassis/suspension guy. My Brother is the engine scientist.... :D :D
Hey Scoot, here is a pic of the Crower EDM lifter with the pressure feed oiling hole in the lifter face. See the tiny hole in the face...? Since I started using these (and the correct oil)I haven't had any flat tappet cam failures...
http://s850.photobucket.com/user/DRT...tml?sort=3&o=0 |
This is a hydraulic lifter ?
Just visited Crowers' website. 'Cool Face' is what they're calling the EDM hole option on ALL Flat tappet lifters.
http://www.crower.com/lifters-web-catalogs |
NO... this a flat tappet hardened face solid lifter, that has been EDM drilled to accept oil from the lifter oil galley pressure into the lifter and down through the EDM hole to provide pressure fed oil to the cam lobes at all times while running. No more relying on oil slinging to lube the lobes, even at idle and especially during break-in... ;O)
NO, YB, they are not optional on hydraulic flat tappet lifters, only the solid lifter flat tappet lifters. it can't be done with hydarulic lifters, it would bleed off the oil pressure and every lifter would be clattering due to like of pressure. I'm pretty up to date with Crower and in fact just ordered a set of fuel injection nozzles today from Jerry, who still makes them at home, since Crower no longer is in the injection business, thay sold all their injection parts and stock to Rons injection.
Zip. |
http://s850.photobucket.com/user/DRT...tml?sort=3&o=0 Yeah DD... but you will break down a motor in a weekend & bei up & racing in no time... welding in oil windage trays, looking at bearings, etc... I would love to spend a day w/ you too!! I saw your build log on the Doba... pretty extensive!!! |
Say it again . . .
Ain't it fun to learn stuff? |
Indeed... RK... indeed. The annual cruise night is here... 6/1. Supposed to "850" cars (pre-74). Gonna take the Chevelle.... it will be a 2-mile loop while idling most of the time. Cars get HOT... LOAD UP... cops everywhere. Running "NET" oil this time.
And the Northwest is supposed to be warming up for the weekend !
Scoot ! I'm gonna be in your neck of the woods July 5- 6-7 for a hill climb. Oakridge for the Larrison Rock Hillclimb. This coming THURSDAY we hit the road for Ashland and the Cascade Lakes Hillclimb on the 7-8-9 |
Originally Posted by zipper06
I don't have the oil holes in any of the roller motors, but i do, is grind a .002 X 1/16"W flat on the top side of the roller lifter in the lower half of the lifters to oil the rollers, that way the rollers get more oil.
Zip. Hey, on another note. Do you remember the advertising claims of "flame hardened camshafts"? :lol: |
Me too Zip. In fact I groove half the set on the backside so both sides have the flow in the direction of the rotating assembly.
Yes Dave that's what i do also and should have said that Hey, on another note. Do you remember the advertising claims of "flame hardened camshafts"? Yes i remember that was an advertizment about flame hardening the cams, although i don't see how that's possible with a cast iron cam, even if it worked i would bet they had to straighten that puppy to get it in the cam bearings :lol: Like i said in a previous post i will have some answers on the hardness issues. I'm taking one solid lift flat tappet two roller cams an a hydraulic flat tappet cam that went flat, plus hydraulic lifters, solid flat tappet lifters and a couple sets of roller lifters, one Crower and one set of comp cams rollers. I don't know how they will test out but i will have accurate hardness, both in the rockwell scale or the burnell scale, since the cast cams will probaly be too soft for the rockwell test. Zip. |
Scoot ! I'm gonna be in your neck of the woods July 5- 6-7 for a hill climb. Oakridge for the Larrison Rock Hillclimb. This coming THURSDAY we hit the road for Ashland and the Cascade Lakes Hillclimb on the 7-8-9 Looking forward to hearing the results of Zips findings. It is so much more real when it comes from a racer... |
Will be racin' 'the ANIMAL' (grey car)
| All times are GMT -8. The time now is 07:18 AM. |
