-   -   Help with whats wrong with engine..... (https://www.racingjunk.com/forums/showthread.php?t=25420)
thor1701 08-23-2009 10:23 PM
well as far as i know i do have oil presure, unfortunitly i only have a stupid light on the dash, thats one BIG thing i hate about that car, its all lights and nothing else, i mean why make them like that i dont understand that
mopar1968 08-24-2009 05:05 AM
Shoot it :!: :!: :!:
''JUST MY TWO CENT'S WORTH''
johnselectric 08-24-2009 02:26 PM
I think It's Morris code --- -- ----- ----- -- ----
"I'm #1 and I am coming out!!!"
FullTimeRacing 08-24-2009 02:36 PM
make another video,but don't move around so much.
focus on the frist rocker arm to the right(passenger side).
I belive I saw it stop moving.
thor1701 08-24-2009 06:29 PM
ok here is the vid you asked for
http://www.youtube.com/watch?v=1FRr8glwkkQ
i pulled the sparks, they all look fine cept for the 3rd.....it was wet...tho i couldnt tell if its from some oil that got splashed out from the cover being off or what....tho it didnt feel oil wet it felt water wet
kwkracing 08-24-2009 06:59 PM
Maybe i was wrong and there is a Wood Pecker inside there!
DirkaDirka 08-24-2009 07:04 PM
You didnt by chance smell them did you?? To see if they smelt like oil, fuel, or antifreeze?
Was it wet at the electrode?
thor1701 08-24-2009 07:13 PM
no i didnt smell then, well, i smelled the wet one and it just smelled like water, meaning didnt smell at all, and it was wet on the part that goes into the engine
THERATTLER 08-24-2009 07:15 PM
Originally Posted by kwkracing
like said before, when the rod is loose, that means excessive clearance, so there is no oil pressure on that journal anymore, so then the cam and lifter are not getting oil up top of that rod either... which makes all the knock,knock and rattle your hearing
I agree with kwkracing , seems pretty obvious , the plug being wet or not has nothing to do that knock...YOU'VE GOT AN OILING PROBLEM .
thor1701 08-24-2009 07:48 PM
i never said the wet spark was causing it, someone had asked me what my sparks looked like so i told them what they looked like :)
THERATTLER 08-24-2009 07:52 PM
:D THATS COOL :D
CamBirdRacing 08-25-2009 08:14 AM
Looking at the #1 intake rocker, looks like you might have some bad lifters. But they normally don't make that kind of sound. That sounds more like a rod bearing or wrist pin. But that #1 rocker sure looks not up to par.
kwkracing 08-25-2009 01:05 PM
Get a bicycle, it will be easier for you to work on.
cepx111 08-25-2009 09:21 PM
Slap the V/C back on drive the wheels off of it till it blows, then you'll know for sure what the the problem was, otherwise tear the thing down and do an inspection.
It's obvious it's an internal issue.
Those engines are notorious for having lots of lifter issues, piston slap and piston pin problems anyway, your beating a dead horse get busy fixing it or buy a rebuilt unit and be done with it.
JMO>Cp
thor1701 08-25-2009 09:55 PM
how bout you buy me one and you can work on it for me :)
thor1701 08-25-2009 09:57 PM
JMO>Cp
well now, if thats what you can do with your stuff, you must have money, maybe you can lend me some and i can get my stuff fixed insted of sitting here asking for help?
kwkracing 08-25-2009 10:37 PM
Well where is the car located?
We are saying it is gonna cost more to fix, because that is a major problem than you could hopefully get a cheap car for.
When any kind of metal gets circulated thru the oil, it quickly wears every lubricated part in the engine. That means the more you start it the more clearance everything gets, not just the loose rod or broke piston you have.
cepx111 08-25-2009 10:50 PM
Didn't mean to sound arogant or calous, for that I do apologize.
You've had multiple people on here give some good advise but instead of acting on it you've been beating around the bush.
It's definelty an internal issue with the motor it's time to break out some tools.
Cp
