-   -   BBC 572 questions. (https://www.racingjunk.com/forums/showthread.php?t=24858)
Dahlton 11-23-2009 02:33 AM
Re: D Drive
Originally Posted by bbchevy
Originally Posted by Dahlton
Originally Posted by zipper06
Hey Dahlton,
How are you running the distributor, with an offset drive? I've never ran a Jessel drive on a b/blk blown motor. I've always used the Donavan gear drive which also put the pump and distributor on the cover, and still do on my sm/blk 1471 motor. I know you can pull an Enderle 110 pump with a belt drive off the crank, any bigger i doubt if you can, but that's big enough for most blown alcohol engines unless you plan to dump a some nitro in it.
On the lighter side a person from Finland bought some parts from Jimmy Smith while he was visiting in the USA a couple yrs. ago. when he got back he sent a bottle of Minttu Snapps, man that stuff is stout, i still have 3/4 of the bottle left. If you get your motor to run as strong as that stuff, it'll be killer for sure.
I have no idea about the distributor yet was hoping a low profile would fit in the stock location I will probably use a crank trigger. I got hold off a Jesel guy and he told me it's ok to run the pump on the cam with the belt drive. So you don't like Minttu snapps if you have 3/4left... if you have not tried it put it in the freezer and keep it there a couple off days and then drink it! (it's good).
I was hoping it would be a killer and make over 1000hp...
Dahlton,
I will be using pretty Much the same set-up?
572"BBC,Jessel Belt Drive with a Cool Chrome/Moly Bracket for the 110 Enderle.The fellow i bought the Belt drive from,ran a Trigger,Crab Style MSD,and He also had a Pioneer Frt Drive set-up.But,the MSD Crab Style Dist with Crab Cap worked Fine with a HH/Retro Littlefeild 14/71.
I will only be Using a 8/71,on the 572.But it will be ON CORN SQUEEZINS,(E85)
I will be using a set of Merlin 345 IRON Heads,8.2-1 Static,775-800-Roller on a 114.I would Hope you make all of a Grand in HP?Cause im Sh@@ting for 14 to 1500........?We'll See.
Later
G 8)
I went with a shorter stroke now mine will be 540cid.
Your engine will be all race right?
I'm not sure but would not more static compression be better when running on e85?
I was hoping to runn smaller cam so the valvetrain would have a easier life.
when you have it dynoed please give results! Would be super to compare!
you have more cui, smaller blower and larger cam.
Will you use a bird?
bbchevy 11-23-2009 02:55 PM
Re: D Drive
Hey Dahlton,
Dahlton,
Later
G 8)
Compression,Bigger Tuning Window with the Low Comp.
As far as the Dyno?Unfortunately,thats Not in My Budget!
I will be using a Hilborn 4-Port MAGNESIUM Bug(want the Nostalgia Look)
I may end up with a Shorter cam?750-760 Range....?
Actually the Dyno with be a E.T.Slip.Race Only
71---75 Chevy Vega.The Car weighed Less than 1900lbs with a BBC and a Glide,when it was out last.So it will be FUN to Hang-On tooooo!
Later
G 8)
Dahlton 12-02-2009 02:01 AM
Re: D Drive
Hey Dahlton,
Dahlton,
Later
G 8)
Later
G 8)
You Vega guys :roll: :roll: :D
I ordered the cam to day a Jones cam... Will be interesting trying something different...
Ehat do you guys think about the spex??
269/[email protected]"
.412"/.412" Lobe Lift
114 LSA
oldandtired 12-02-2009 12:49 PM
Re: D Drive
114 LSA
I would run 1.8 rockers. JMO. Dave
bbchevy 12-02-2009 03:41 PM
Stick
Dave,
I was thinking the Stick is a Bit short in the Lift?
I ALWAYS liked the 722 Lunati Grind.
Later
G 8)
bjuice 12-02-2009 03:52 PM
Re: Stick
Dave,
Later
G 8)
ran that same lunati cam (722/722) in my 511...awesome cam !!!!...Tom (Topsportsman) has had luck with this same cam in the past years..
cepx111 12-03-2009 12:01 AM
X3
The 722/722 lunati is one bada$$ cam, I know couple other racers at my track that run it with outstanding results.
Me and Landon run that same grind in our 496's too.
It's funny, theres are a couple guys with (540's) in pro we're giving a run for their money.
They run alkay, have bigger cams and ported out BB2X's - we run 110 race gas and cast iron heads. :shock:
Alot to be said about the right combo.
JMO>Cp
bjuice 12-05-2009 04:30 PM
found Old cam card.
http://i391.photobucket.com/albums/o...2050920181.jpg
zipper06 12-05-2009 04:49 PM
The Lunati .722 works well normally asperiated, but don't forget he's running blown, so he needs a little more lobe seperation for it to breathe good (Lunati 110*) his is 114*
I've got a similar .725/.725---271/275---108 lobe seperation for the 496" i'm building for a customer.
bjuice 12-05-2009 04:53 PM
thats correct Zip i didn't read back thru the post and see where the Blower was mentioned..i just went down the List of his initial post..and still missed the part about the blower..lol
definatley needs a 114 Lobe seperation.
i ran this cam on all muscle.
Dahlton 12-07-2009 01:30 AM
Yep have to force feed because I'm not rich.
Found out last week that I have to change pistons.
I bought the un-assembled short block from a las vegas company and when I started to look closer on the pistons I found out that they were waaaay wrong!
so I got PO:ed and have now ordered a custom set from BME that should fit better...
So I may not be able to run this summer but we'll see
kwkracing 12-07-2009 10:08 AM
True, must low budget guys are running blown 632's around town. I wonder what the rich guys have?
jk. lol
Dahlton 12-08-2009 01:26 AM
jk. lol
rich guys have barton Hemis and over 800cid natural aspirated engines :D
