-   -   fuel problems (https://www.racingjunk.com/forums/showthread.php?t=34113)
hammertime 12-31-2013 02:19 PM
12an to the pump (need a big filter also Enderle is prefered) 10an to regulator, 8an to carb is plenty.
Your confident its not a carb issue, them C&S carbs with them floats have been known to be a issue.
reeltime 03-26-2019 12:21 PM
Yes many things can cause this. What is your fuel pressure when this breaking up happens ?
SallyPearsons 07-04-2024 07:52 AM
How much actual HP are you making? That pump should EASILY supply your motor, even on alcohol.....
