496
What kind of budget can you afford will limit everything... If you plan on running pump gas i would keep the cam in the 660 lift range or less, if you plan on spraying it everyrun then you could go way bigger on cam...
496's rule... Ryan |
| All times are GMT -8. The time now is 02:51 PM. |
