-   -   Bbc hp est (https://www.racingjunk.com/forums/showthread.php?t=32652)
ejm 09-28-2012 05:22 PM
Stock heads but I can run a roller cam, which I will do next year.
BEAST477 09-29-2012 08:56 AM
That would help and some GM rectangle port iron heads would help too.
I'm assuming the 781's are oval port.
ejm 09-29-2012 10:42 AM
yes they are ovl ports but with some work they will be fine builder was think they would have more torque at the end of the track so it wont fall on its face
wazup 09-29-2012 11:23 AM
The 781 oval ports will give you more torque and lower end power. Put some bigger valves and some port work and i think these heads will work better than the 990 heads. Good luck ejm and have some fun.
ejm 10-01-2012 10:20 AM
well got her going and wont really idle right and went down the track great but header glow at end of track any ideas
hotrod1994 10-01-2012 01:22 PM
check your exhaust gas temps
check the timing it maybe running rich and the timing may be too far retarded most common cause is not enough timing and too much fuel
ejm 10-01-2012 02:53 PM
I had total timing set at 30* think I should go higher?
BEAST477 10-01-2012 04:49 PM
I would start at 36* and work from there in 2* increments up or down.
ejm 10-01-2012 04:54 PM
maybe thats why when it "dogged" down at the end it flat out almost died under 3000 rpm (dist not locked)
BEAST477 10-01-2012 04:59 PM
How do you leave the line when pulling? Do you foot brake and at what rpm?
