-   -   Gearing new car (https://www.racingjunk.com/forums/showthread.php?t=32252)
fast75vega 06-22-2012 03:53 AM
NO pvc pipe for the roll cage though ! :shock:
lol... i wish i had taken some pics :wink:
coolracing 06-23-2012 07:37 AM
Rite on ill forget the spray with this motor and I shouldnt have a problem with consealing weight due to the fact that most impalas are a helluva lot heavier than mine. But anyway ya its being built for grudge racing.
BEAST477 06-23-2012 01:00 PM
Well just to give you something to compare to, here is my combo.
'65 Nova, 540BBC 12.6 comp Reher- Morrison cam .808int .765ex, Turbo 400, Dana 60 4.56, Hughes 9" conv 5800 stall, 2870lbs with me in it.
Has run a best of 8.99@ 149. Crosses the stripe at 72-7300. I run a 33x16.5 tire now thinking of going to a little shorter tire on the next set.
Just something to think about.
maxpower671 06-24-2012 09:57 PM
why no duration specs? lobe sep? fuel?
nice power, performance btw
bjuice 06-25-2012 06:27 AM
How short ya Going Beast, Your rpms sound close...how much you want to turn that 540 ?
BEAST477 06-25-2012 04:33 PM
Didn't have my cam card in front of me at the time but here are the specs: .808int .765ex dur @.050 284int 298ex 112 lobe sep.
I'm running a Quickfuel 1250
Oh and I'm running Brodix BB2X that flow just over [email protected]
BEAST477 06-25-2012 04:38 PM
Probably to a 14x32 or 14.5 x32 got to check the rollout #'s
Well B I was thinking 250-300 more at the stripe. I really need to get the thing on a dyno and find out what it makes and at what rpm.
maxpower671 06-25-2012 05:29 PM
-thanks Beast! i like the numbers! :wink: nice combination
bjuice 06-26-2012 01:05 PM
dyno's are a good thing...to tune..not all the numbers they put out are realistic in a car,,,but you know this already...I think your doing the right thing...put a 32 on it and check the Roll out 1st to make sure they are shorter then what you have and run it....nothing will tell you more then the seat of your pants and The ET/MPH just back up what you feel,,,when it comes to gearing situations anyway..all the 4 and 6 speeds I ever owned and even a few automatic's (without electronics) I always shifted with what My a$$ was feeling...and that was normally just before the car nosed over... 8)
