-   -   Oil pressure too high. (https://www.racingjunk.com/forums/showthread.php?t=31761)
fla1976 03-03-2012 07:53 AM
The only time I saw oil being forced out of a dipstick tube was on a Ford 302. The head gasket had blown and it was forcing compression pressure through an oil passage and pressurizing the crankcase. The car was in for a bad alternator. The dipstick tube was filling the alternator with oil, burning it out. A compression check located the bad cylinder, and a new head gasket and alternator fixed the problem.
Slngsht727 03-04-2012 05:22 AM
Originally Posted by roadkill2
A quick 2 cents worth here . .
If he has extremely high Oil Pressure and has oil squirting out of the dipstick tube, he has TWO different problems . .
Better find out how much oil he has in it first.
Then figure out what (or why) the oil pump is being so efficient!
I have a great memory... just short. I had forgotten this. The first time we drove it around the block I saw smoke coming from under the hood. When I popped the hood, the oil filler was out and the dip stick looked like it had overflowed. I checked the oil and it was almost a quart over full. Seems that during assembly they did some pre lube, then poured in five quarts after installing the engine sometime later. I drained off less than a quart. At that point it had been driven 24 miles. I don't think it's overflowed from the dip stick since.
Slngsht727 03-04-2012 05:31 AM
That oil filter isn't ORANGE is it ?
:shock: :shock:
I relaced a Fram PH30 with same.
fast75vega 03-04-2012 05:36 AM
:shock: :shock:
stay away from them orange filters....... they can be deadly to a race engine :(
Slngsht727 03-04-2012 05:42 AM
Originally Posted by fast75vega
i wonder if you to have a few blocked oil ports which i seen make the oil pressure run high. :? i know my motor in my drag idles at like 45-50psi and i get like 90psi on the gas
I think I'm going to try a new oil pressure sender and gage. Might be getting a bad reading if one of those are bad.
roadkill2 03-04-2012 07:27 AM
Try one at a time . . Then you not only will fix the problem (if it does) but you'll know what you fixed . .
TheYellaBrick 03-04-2012 07:29 AM
Orange filters discussion:
http://forums.racingjunk.com/viewtop...am+oil+filters
:shock: :shock: :shock: :shock:
Slngsht727 03-04-2012 10:58 AM
Okay, so I had an extra sender in the drawer and decided to start with that. Swapped them out and fired it up. The oil pressure was about 35 psi. What a relief! I'm going to read about the orange filters. Thank you to everyone that responded.
fast75vega 03-04-2012 05:38 PM
i was figuring u were running an aftermarket oil pressure gauge and line..... lol
Slngsht727 03-04-2012 07:13 PM
Yep, that's my idea of trouble shooting... just keep throwing money at it until it works!
For a minute there, I thought I had me a new 350 Chevy boat anchor.
