Not my picture but this shows the idea perfectly. I use a triangle shaped file and cut the slot about .020" deep. Time the groove so the oil goes onto the gear right before it meshes with the cam.
http://www.powerperformancenews.com/...12/GEAR-07.jpg |
Originally Posted by scott0408
(Post 251251)
running a 421 sbc after a year of
(Post 251251)
Speed Test racing doing some work on it & found the dist gear worn not extremly bad but still makes me worry about it any ideas
. It's not uncommon. You can usually pick that up with a timing light is will show eratic timing when you check the timing. Hope this helps. |
toi hieu ban
| All times are GMT -8. The time now is 08:32 PM. |
