just got back from napa and the guy said the battery was at 480 when it should be at 650, he said charge it and it should be fine
Charge it?? :shock:
Napa told you that? That's what the alternator is supposed to do! Rabbit is right, the alt is not charging, or the battery is not taking a charge or at least not holding it. A rainy or snowy night with all the lights,heater, and wipers running will catch you if you don't get it now. Jmo :D good luck to ya |
Check the alternator belt.With the motor NOT running try to turn the alternator pulley by hand.If you can turn it at all the belt is loose or worn. Bill.
| All times are GMT -8. The time now is 02:38 PM. |
