Originally Posted by ccperf721p
It's probably a race prepped housing with a fill cap welded on the top and sealed axle bearings. 2 quarts would be plenty.
still should have the level plug on the side of the carrier shouldn't it ??
Mine has both.
Most rearends take around 3 quarts to fill completely to the "level plug" located on teh side of the housing, usually it's a inverted 3/8 square drive.
In race trim though, most guys will cut that amount by about a quart, hence the 2 quarts recommend. I run 2 qts in my dana 60 and its alot bigger than a 9 housing :wink: |
Right on...
Originally Posted by fla1976
The fill plug should be on the side of the housing a little higher than the level of the pinion gear. It sounds like you are looking at the pressure vent on the top of the housing.
Thanks for all the help everyone!!! Im good to go. Will be using Richmonds synthetic 75 - 140 .
Re: Ford 9" rear end
Originally Posted by Shaybliss71
I just bought a new car and it has a braced ford 9". I would like to know how much rear end dope goes in? Three quarts or ? Thanks
| All times are GMT -8. The time now is 09:32 AM. |
