I've had a good many 010 blocks bored .060 & never had a momments trouble, but I'd never go .080 over :shock: , IMO> thats just asking for it.
Bottom line, have it thoroughly checked out by a competent machine shop. |
i had a 350 block bored to 4.125 because we had all the other parts laying around and needed a motor asap. we filled the bottom 1/2 with block filler. It ran a little warm :D I'd come in after a 15 lap feature @ 250*. This is in a imca modified, i turned it 7500, ran it about 10 races to finish out the season.
Running a .060 over block now with no issues,of course it filled from the waterpump holes down.Used a many of .060 blocks without issue..
Originally Posted by Tod74
Originally Posted by hink
At .060 over on a 350 block I would sonic test first as we have not seen many blocks that would make .060 over and be used in a performance application.
We had a customer bring in a block and it sonic tested .120 on the thrust side and he said the core shift was good but I said its not a very good indicatior. At .060 make sure its plate honed as well. |
One thing to keep in mind, from .060 to ,080, the cylinder is only .010 thinnner, as its a diameter. .010 isn;t much, and won't make or break it.
Frank |
| All times are GMT -8. The time now is 07:16 AM. |
