-   -   Whats your ride look like? (https://www.racingjunk.com/forums/showthread.php?t=28240)
burnskustomz 06-11-2010 07:46 PM
Dog track? I'm gonna take it to the tires store and let them align it when I get a chance!! but yea the frame is bent to the right and I talked to my dads friend I think we might try to put a torch to it and pull it back straighter!!
cepx111 06-11-2010 11:25 PM
Any good frame/body shop will make short work of that tweaked frame, sure is cheapper than the alternative, a new one, if did have to go that route it would be better to just get another truck.
Replace the flexible rubber brake lines for that brake pull, they're bad about collasping internally.
Cp
burnskustomz 06-12-2010 05:05 AM
Just spend hundreds of dollars on the brakes at the college and they don't charge for labor all new brake lines!! Brake rotors and drums turned also new brake pads/shoes!! And can't get a new truck to much scentamental value and I can get a frame for around 100 bucks or so!!
DirkaDirka 06-12-2010 09:56 AM
The best advice I can give you is to take it to a frame shop or a body shop to straighten the frame. Do not and I say again DO NOT put heat to the frame. When you heat it up you make it weaker in that spot. Even if you try to cool it down really fast by pouring water on it. When you pour water on it you are also making it more brittle. So take it down to a place that can straighten it out for you.
rabiddawg 06-17-2010 05:22 AM
406 cu inch brodix 8B 1000 aluminum smallblock 13:1 compression
callies super light forged crank
Jet titanium rods 5.7
wisco forged pistons
C&A zero gap rings
Brodix -10 heads (extensive mods done )
2.080/1.600 valves int/exh
titanium valves
isky roller cam
Crane 1:6 roller rockers on intake 1:5 on exhaust
crane rev kit
rocker stud girdle
headman 1 3/4 husler headers
super Victor single plane intake
AED custom 950 cfm carb.
NOS super powershot NOS system
cog belt pulley system
3800 stall hughes converter
TCI competion TH350 trans
transbrake
Dennys aluminum driveshaft
Moser shortend 12 bolt with 4:11 gears
comp enginneering slide a link traction bars
my web page with more pics
curtisreed 06-17-2010 05:28 AM
Dawg,
That must be one steep hill you're trying to get that Camaro up. :lol: :lol:
Curtis
DirkaDirka 06-17-2010 05:41 AM
Dawg,
Curtis
Well it is a Chebby. Now a Ford would have no problem getting up that hill. :twisted: :P :lol:
J/K
In all seriousness that is one nice azz Canaro
suicidebomb 06-17-2010 08:34 AM
Dude, life size pictures are not necesary.LOL
