Dude the car is slowing that motor down you just need to give me the car!
LOL Nice ride |
Re: First Test n Tune
Originally Posted by cam67152
Well, last weekend was the first time on the track with my car. I've been building this car for the last 6 years on and off. The track is only 380ft but its close to home. The car ran great had no issues but I thought my 60's would be better, I know that cam isn't the best for drag racing, it's just what I had. is it hurting it that much? here's the list. what do you guys think?
60' 1.60s 330' 4.51 72mph 67 camaro all steel except hood 9" 4:30 gears, 29x12 slicks powerglide 1.76 pro brake 8"vert with 5200 stall aerospace discs all round BBC 496 13:1 srp pistons scat forged rotating assembly brodix racerite oval port heads edelbrock tunnel ram two 600 holleys isky hyd. roller 284 294 @ 50 600 lift 110 lobe sep. http://img46.imageshack.us/img46/4251/dscn9819.jpg http://img100.imageshack.us/img100/16/dscn9823.jpg Thanks guys, cam67152 |
The tunnel ram is what is killing the short times. JMO
I finnaly got the car out on a full quarter on Aug 8.
I loosened up the front shocks and softened the rear and was rewarded will a 1.46 60ft I think there is still a litte more in it. I hope to ditch that cam,carbs and intake go to a solid roller, victor and dominator for next year. This cam was out of steam well before the finish line. I know this is a mismatch of parts, got such a awesome deal on this motor I would have paid as much for a good short block. 1.46 60ft 10.80@ 121.89mph with help from my crew chief http://a.imageshack.us/img814/7350/dscn0460n.jpg cam67152 |
What rpm are you going thru the traps at? 1/4 ?
the gearset may be hurting you, How heavy is the car, Stall ?? We have a 2000 lb firebird that runs that gearset with a 565 in it. same 430 rear. |
You need better heads and a better cam. 13 to 1 compression and racerite oval port heads? Even if they are the biggest one's they're marginal for that size engine. A solid roller with a decent set of heads should make a nice difference. Personally I'd keep the t-ram and carbs, maybe upsize to 750's later on. A t-ram is the cheapest way to get 30-50 hp. Plus you get that super responsiveness you just can't get with a single carb.
A t-ram is the cheapest way to get 30-50 hp. Plus you get that super responsiveness you just can't get with a single carb. |
the gearset may be hurting you, How heavy is the car, Stall ?? We have a 2000 lb firebird that runs that gearset with a 565 in it. same 430 rear. 5200 stall I haven't weighed the car yet, I'm thinking its around 3000lbs cam67152 |
| All times are GMT -8. The time now is 04:36 AM. |
