Zip,
When we changed from carb to injection back to carb. When we made the switch we worked with Rupert that way we did not have to have the regulator and bypass. We drilled the pill until the fuel pressure was correct. |
thanks, guys. i'll look at his setup and see what i find. charlie
Originally Posted by shawnp
Zip,
When we changed from carb to injection back to carb. When we made the switch we worked with Rupert that way we did not have to have the regulator and bypass. We drilled the pill until the fuel pressure was correct. Zip. |
| All times are GMT -8. The time now is 08:33 AM. |
