-   -   jets (https://www.racingjunk.com/forums/showthread.php?t=27637)
john910 03-21-2010 05:14 AM
jets
makes sence. i put them on for nostalgia looks on my 32 austin. to run in nostalgia races.
john910 03-21-2010 05:19 AM
jets
also , what about going to e-85 or alcohol
TopspeedLowet 03-21-2010 05:21 AM
Re: jets
That is usually the logic for running a zoomie set up on a gasoline carb engine.
Sorry if you did not know that would likely be the net of the use of them. You most likely have a very happy engine once you check all the usual carb adjustments to be sure they are correct with any other exhaust system but the one you have.
Bruce
john910 03-21-2010 05:39 AM
jets
last year i ran headers , just wanted to change the look. maybe i'll use the headers when i run weekly, then use zoomies for the nostalgia races and just pust up with a little black smoke.
