Originally Posted by ajk
Originally Posted by cncmotorsports
You hear these stories cause they don't cam them right, and people use crappy heads.
Don't be surprised with pro comp heads this motor is done making power at 6200-6300 rpm.. 1 bad part in the balance of these components will make the engine suffer. We build 383s for drag race and circle track designed to run 8000-8200 RPM. Good heads, AFR, Dart, RHS, Brodix and Edelbrock are not to bad. |
cnc dont see the balaning being an issue friend of mine built one for circle track lasted 3-4 seasons with nothing more then freahening bearings for his own peace of mind then when he rebuilt no major issues in side just went through it again for peace of mind so i dont know where your coming from
I was not referring to the engine balancing it's Self. |
[quote="cncmotorsports"]
Don't be surprised with pro comp heads this motor is done making power at 6200-6300 rpm.. 1 bad part in the balance of these components will make the engine suffer. We build 383s for drag race and circle track designed to run 8000-8200 RPM. Good heads, AFR, Dart, RHS, Brodix and Edelbrock are not to bad.[/quote 1 bad part in the balance of these components will make the engine suffer. read your own post |
I did...
What don't you understand ? |
MAKE sure to check your crankshaft for cracks when using eagle. Jmo..
Don't be surprised with pro comp heads this motor is done making power at 6200-6300 rpm.. 1 bad part in the COMBINATION of these components will make the engine suffer. We build 383s for drag race and circle track designed to run 8000-8200 RPM. Good heads, AFR, Dart, RHS, Brodix and Edelbrock are not to bad. There, fixed it to save arguments. |
| All times are GMT -8. The time now is 01:54 PM. |
